Old 20-05-2006, 01:13 AM   #1 (permalink)
Default AVI to DVD
Hi,
I would like to convert my divx movies to DVD.How can i do this?.
I got a lot of guides..they all tells how to convery one avi to DVD..Now a days we can see a lot of combo DVD's..ie: 2 or 3 movies in one DVD.How can I put more than one movie in to a dvd...so that there will be a menu to select the different movies....like 3 in 1, 5 in 1 movies...i have many divx movies in the range of 700 MB.....how many movies can i put in one DVD(in DVD format.....)
anilthomas26 is offline
Old 20-05-2006, 11:11 AM   #2 (permalink)
Default Re: AVI to DVD
its to simple use imDVD ripper
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 20-05-2006, 11:46 AM   #3 (permalink)
Security Exp
47shailesh's Avatar
Use Adobe Encore to create DVD menu thoug it is a heavy s\w but cutomization offered is uncompareable
47shailesh is offline
Old 20-05-2006, 12:13 PM   #4 (permalink)
how many movies can i put in one DVD?
Old 20-05-2006, 12:50 PM   #5 (permalink)
Security Exp
47shailesh's Avatar
depends what DVD type ur usin DVD-5 can accomodate 4.2gb data DVD9 can accomodate 8+ Gb data.
