Old 19-05-2006, 08:53 PM   #1 (permalink)
ionicsachin's Avatar
Unhappy Monitor size reduced....
My PC is provided with 400Watts PSU. I recently purchased a XFX GeForce 6600 GT AGP 8X card, for a few days the display was full stretched to full screen. After some days i dont know how the display is reduced and a gap of abt 1 cm is left on both sides. I reinstalled the drivers several times( also several versions). Please recommend some cure
ionicsachin is offline
Old 19-05-2006, 10:02 PM   #2 (permalink)
digiFriend's Avatar
Default Re: Monitor size reduced....
try different screen resolution,and if you see gap in different resolution then-
there are control on monitor to stretch the screen.
you never know what you can do until you try
digiFriend is offline
Old 19-05-2006, 10:43 PM   #3 (permalink)
aryayush's Avatar
LOL! It's so simple to solve this.
Right click on the desktop and select 'NVIDIA Display >> [Monitor]'. In the menu that appears, select 'Screen Resolutions & Refresh Rates'. Move the 'Screen resolution' slider to the resolution you want (slide it to the extreme right for highest resolution) and select 'Highest (32 bit)' from the 'Colour quality' drop-down menu. Under 'Monitor Settings', enable 'Hide modes that this monitor cannot support' (though it should be enabled by default) and select the highest refresh rate from the 'Screen Refresh Rate' drop-down menu. Click on 'OK' or hit return (Enter). You're done. The screen will flicker and will stretch and fit to the corners of your monitor screen.
If, however, this doesn't work (though it should), then you will have to use the buttons provided either below the screen or on the right side of the monitor.
Hope this helped!
aryayush is offline
Old 20-05-2006, 09:08 AM   #4 (permalink)
Question Re: Monitor size reduced....
I have tried that all. I tried all refresh rates under all resolutions. But its of no use. And also the space 1 cm is left over on both sides when the screen is stretched by 100 units. But i feel the problem is with my monitor because if the graphic card gets even a bit less than full power it requires, it ll give no display. And also the space on both sides is left over even in BIOS screen ( fully stretched).
Old 20-05-2006, 11:14 AM   #5 (permalink)
The Researcher
I think your graphic card is on the way out.
Ramakrishnan is offline
Old 20-05-2006, 04:34 PM   #6 (permalink)
But my graphic is perfectly OK. All the games and 3 D softwares are working fine. I tried keeping my old MX440 but the problem was still there
Old 20-05-2006, 04:42 PM   #7 (permalink)
khansdream's Avatar
Arrow Re: Monitor size reduced....
There is no problem with software or the graphic card. The monitor is getting down. Check if ur monitor is grounded properly.
If ur monitor power cable is attached directly to the SMPS of Cabinet, remove it and plug it directly to other point.
khansdream is offline
Old 22-05-2006, 03:48 PM   #8 (permalink)
aryayush's Avatar
I may be wrong but isn't it normal that there is a bit of space left on the borders? I mean, a millimeter or two should be there even if it is perfectly okay.
aryayush is offline
Old 22-05-2006, 08:09 PM   #9 (permalink)
Yes, I myself keep 2 or 3 mm on all four sides.
But in his case, it is 10 mm which I think is too much.
V.Prem Kumar
janitha is offline
Old 23-05-2006, 10:49 AM   #10 (permalink)
khansdream's Avatar
Post Re: Monitor size reduced....
10mm is too much. And I am sure if he doesn't check the power suppy (to monitor) that 10mm will grow and soon he will find a tiny pixal in the center of the screen......!!!
Old 23-05-2006, 07:31 PM   #11 (permalink)
But I dont understand it. The monitor has its own SMPS and is supplied with normal 230V AC whether it is from mains or UPS or the extra socket in the SMPS of the system. (in which case it is only a bypass socket and not powered through the SMPS circuit)
In such a case even if the supply can affect the display size it can only be due to variation in the voltage. Then at least when the voltage is normal, the screen size should be normal.
Pl correct me if I am wrong.
V.Prem Kumar
janitha is offline
Old 24-05-2006, 05:46 PM   #12 (permalink)
aryayush's Avatar
There's still some time before that happens, I suppose!
aryayush is offline
