How do i make CD's autorun? my autorun file is an html file. Another thing my digit CD's do not autorun aventhough autorun is enabled. old CD's autorun without any problem. CD's after August are not autorunning! I have an LG 52X32X52X CD writer and run windows XP pro
the autorun file is a .inf file. its pretty simple to create but there is an program which creates such files with no hassels. gimme your email id and i ll mail it to you.
as for the digit cds i think its cause your flash player is not the latest. i had the same problem . get the latest player
Explorer automatically looks for the autorun.inf file in the root
directory.This file specifies the action to be executed and also the icon to be used for the cd in explorer.
