Old 17-05-2006, 11:45 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Question Hdd light blinking ! ! !
evenif my comp is idle, HDD red light is contantly ON or BLINKING asif i am working ...
whot 2 do ???
ax3 is offline
Old 17-05-2006, 11:49 AM   #2 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
Default Re: Hdd light blinking ! ! !
Check if some service is running in background (It happened to be Indexing service for me)
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 17-05-2006, 11:54 AM   #3 (permalink)
khansdream's Avatar
Post Re: Hdd light blinking ! ! !
HDD light glows when HDD is on work, if you are not working on it, then most probably some TSR is running.
khansdream is offline
Old 17-05-2006, 01:07 PM   #4 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
It means:
-Running Services in Background
-Some virus active in background
-Your HDD gone crazy
For first, Run task manager and check for processes that do not belong to the list(you will need experience for that), and stop the unnecessary ones.
For second, scan your hard drive with your favourite AV and remove any infected files. If nothing shows up, use HijackThis and remove thw infected files. Download :http://www.spywareinfo.com/~merijn/downloads.html
(It should be probably the second, cause I had the same prob).
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 17-05-2006, 02:07 PM   #5 (permalink)
Wandering in time...
Ankur Gupta's Avatar
maybe it is the indexing service tht is going on in the background!
try disabling it and then c.
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 17-05-2006, 02:28 PM   #6 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
@ax3
U can also post the screenshot of the Task Manager, so that we can identify the cause...
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 18-05-2006, 11:34 AM   #7 (permalink)
ax3
ax3's Avatar
stoped indexing ... & its working ... THAnX a lot ...
ax3 is offline
