Old 16-05-2006, 11:35 PM   #1 (permalink)
powering up
Mohnishgs's Avatar
Wink Every thing about telnet?
Can someone tell me everything about telnet. I know that its used to carry out DDoS attack. Please email me at mohnishgs@gmail.com
Asus P5KPL-CM
Intel C2D e7300 @ 2.66ghz
4gb Transcend ram
Palit HD4830 512mb gfx card
Western digital 500gb hdd
Dell 17" lcd monitor
Mohnishgs is offline
Old 17-05-2006, 01:48 AM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: Every thing about telnet?
DDos attack.......u wanna implement that? Neways thats ur wish! But Telnet is not a tool for implementing that. Telnet is just a tool for u to get into console mode on some remote/local node.
For DDOS attack u need "ping" command. Well to teach u how to do that is Against de forum rulez.
One thing more DDos attack is of no use in todays scenerio coz everybody today has high speed net connections + there is's an improvement in todays operating systems network buffers/stacks.
Try the DDos on win95/98 and then on Xp....u'll know what i mean!!
mediator is offline
Old 17-05-2006, 08:26 AM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Look here: http://en.wikipedia.org/wiki/Telnet
kalpik is offline
Old 17-05-2006, 11:07 AM   #4 (permalink)
Brat-Man
Posts: n/a
Precisely.. Telnet is Not an Application which is used to Carry out a DDoS Attack.. Its Merely a "Window" into another Remote System..
i.e You Can Access the System's Console / even GUI with Telnet.. More like Windows XP's Remote Access..
If you Have a Broadband Router.. Try to Telnet the Gateway..
i.e " telnet 192.168.1.1 " ,You Can Access the Router's Operating System (Which is Probably Stripped Down Linux)
