16-05-2006, 11:34 AM
Delay in IE Loading
After getting connected IE takes a long time (all other browser like firefox also) to load (approx 1 to 2 mts).
Any remedy?
____________________________________________
A person who never made a mistake never tried anything new.
16-05-2006, 12:04 PM
Re: Delay in IE Loading
Delete all the temp files; lower the amount of disk space to use.
16-05-2006, 02:45 PM
I am extremely miticulous in these cleaning business. Any other remedy?
16-05-2006, 05:54 PM
does this problem persisit in opera also ?
Incompatible message format
16-05-2006, 10:51 PM
Yes, with all popular borwsers
16-05-2006, 10:54 PM
Microsoft MVP
Which net connection r u using?
17-05-2006, 11:47 AM
Yes, it might be a compatibility problem with Browser version and ISP.
17-05-2006, 01:10 PM
Level 96 Headbanger
Your HDD might be nearly full. You should better clean up. Also check for SpyWare and viruses.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium (Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 ( New :twisted:), Roland MicroCube Amp.
17-05-2006, 08:11 PM
by loading, u meant the website to load or the program to startup ???
17-05-2006, 08:15 PM
if it's about the delay in the program startup,it could be due to the add-ons/extensions installed in IE/Firefox.
17-05-2006, 08:36 PM
Distinguished Member
also check for malafide browser add-ons.
use freeware small utility 'winpatrol'
www.winpatrol.com
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
17-05-2006, 09:06 PM
for Firefox :- try installing Fasterfox
for IE :- if u r using IE7, switch over to the beta 2. the preview is extremely slow.
19-05-2006, 07:09 AM
Checked for spyware & viruses.....HDD 50% full. Dataone 256. Still same prob.
19-05-2006, 07:30 PM
I face the same problem but only with Internet Explorer. Opera works fine. And since I very rarely use that crap (IE), I don't care much.
19-05-2006, 11:35 PM
Thanks to all. Checked all the advices of all Digit friends... but same problem in delay in programme loading...not website. When loaded...very fast indeed.
One thing I did not try......IE7.
Should I TRY.......waiting for your opinion.
Thanks again
20-05-2006, 11:37 AM
Try it. And tell us your experience.
And make sure if your ISP is recommending any specific version of IE.
22-05-2006, 02:05 AM
i had the same prob with IE, so i swithched to mozilla firefox...coz...doesn't matter it takes time to start for the first time but for later surfings we can use new tabs..that is much faster
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
22-05-2006, 03:26 AM
it high time u left the BIG DADDY and went for something better
22-05-2006, 01:04 PM
#19 (permalink)
Any remedy?
try cleaning the cache
go to control panel-network and internet connections-internet options-delete cookies/files(check delete all offline content)[FOR IE only]
22-05-2006, 10:46 PM
#20 (permalink)
All done...I do it every time after disconnecting.
Can anyone tell me about IE7??
24-05-2006, 05:32 PM
#21 (permalink)
Forget IE7. Use Opera or Firefox (Opera is recommended though).
24-05-2006, 10:21 PM
#22 (permalink)
must be some kind of spyware or worm!!
think u will never see the devil?
look in the mirror and u will see one!
Search this Thread |
