Old 13-11-2004, 05:43 PM   #1 (permalink)
s_arka_r's Avatar
Default build java executibles
Can anyone tell me for heavens' sake how to build a java self-executible program in JAVA ?
- @rka $ekh@r $@rk@r
@ Kolkata
s_arka_r is offline
Old 13-11-2004, 06:45 PM   #2 (permalink)
aadipa's Avatar
with java u will create JAR files that will run the startup class of ur program.
u will need to create menifest file for it.
here is a procedure to create jar files. -
-http://csdl.ics.hawaii.edu/~johnson/613f99/modules/04/jar-files.html
u can also register JAR extension to run directly by double clicking.
just associate .jar extension with
java.exe -jar %1
command
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
