View Poll Results: Which One is the Best??
Windows XP 2 7.69%
WIndows XP SP2 24 92.31%
Voters: 26. You may not vote on this poll
Old 15-05-2006, 10:29 AM   #1 (permalink)
cooldip10's Avatar
Question Confusion!!
hey i'm confused about what to install- MS Windows XP or Wimndows XP SP2.
Windows XP-
takes less time to boot up and pretty faster. No unwanted reports given during any work.
Windows XP SP2-
Takes much time to boot up (and shut down also). Very secured. Reports are given everytime.( irritates much more).
So please vote so that i can have the best OS....
Everything is Possible
cooldip10 is offline
Old 15-05-2006, 11:21 AM   #2 (permalink)
Default Re: Confusion!!
It's true that SP2 increases the boot up time, but I didn't understand the part about the unwanted reports. As far as I know, all logging and reporting can be disabled manually.
If you don't use the internet on a particular PC then you can get away without installing SP2 since you won't need the security related hotfixes. But if you use the internet, you must have SP2 installed.
drvarunmehta is offline
Old 15-05-2006, 11:25 AM   #3 (permalink)
vysakh's Avatar
what are you waiting for?? install SP2
Incompatible message format
vysakh is offline
Old 15-05-2006, 11:54 AM   #4 (permalink)
abracadabra's Avatar
r u looking for a secure pc or an open pc for all those trojans and backdoor irrantants and viruses. if u looking for a secure pc go for XP with SP2. though the system is not completely fool proof i suggest have a gud anti virus solution and an anti spyware solution that is updated frequently and u r computer scanned often.
abracadabra is offline
Old 15-05-2006, 05:49 PM   #5 (permalink)
cooldip10's Avatar
But what about the security msgs like the tray icon on the task bar..
Old 15-05-2006, 06:07 PM   #6 (permalink)
dIgItaL_BrAt's Avatar
U can disable the security center alerts from the control panel.
dIgItaL_BrAt is offline
Old 15-05-2006, 08:55 PM   #7 (permalink)
Start > Run > type "services.msc" > then press enter
Disable the Security Centre service
Old 15-05-2006, 10:13 PM   #8 (permalink)
phatratt's Avatar
i don't find it a real necessity of upgrading to sp2 incase if u don't have any net connection.For those with one shuld consider upgrading to sp2 and keep constantly updating to stay away from problems.
Growing old is mandatory; growing up is optional.
phatratt is offline
Old 16-05-2006, 08:55 AM   #9 (permalink)
aryayush's Avatar
Of course you should install Service Pack 2!
Even if you don't have an internet connection now, you might decide to get one in future. For faster booting, you can always use 'Hibernation' if you have a single login (because the system tends to slow down if you hibernate a lot on multi-user systems).
aryayush is offline
Old 21-05-2006, 09:44 PM   #10 (permalink)
william's Avatar
go for windows XPsp2 because of the more security and lots of feature.
The secret of creativity is knowing how to hide your sources.
Albert Einstein
william is offline
Old 21-05-2006, 11:01 PM   #11 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
SP2 definitely!
NOTE: This line has been added to fulfil character limit!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 22-05-2006, 05:00 PM   #12 (permalink)
aryayush's Avatar
13:1
I suppose you have got your answer!
Originally Posted by Vishal Gupta
SP2 definitely!
I don't know how much spam this implementation has prevented but I am willing to bet that the number is not too high. In fact, it might have prevented a lot of useful, but short, posts. Please remove this obligation guys!
aryayush is offline
Old 23-05-2006, 10:04 PM   #13 (permalink)
the deconstructionist's Avatar
Talking Re: Confusion!!
waiting a minute longer is better than getting the system infected. Go for sp2
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
the deconstructionist is offline
Old 23-05-2006, 10:37 PM   #14 (permalink)
GaurishSharma.com
gary4gar's Avatar
windows-xp sp2
gary4gar is offline
Old 27-05-2006, 12:50 PM   #15 (permalink)
jamyang312's Avatar
go 4 win xp sp2 for security and vanilla one if u want to be a victim!
think u will never see the devil?
look in the mirror and u will see one!
jamyang312 is offline
Old 27-05-2006, 04:45 PM   #16 (permalink)
tuxfan's Avatar
Of course SP2!!
(Damn the 30 char limit!)
tuxfan is offline
