Old 14-05-2006, 09:21 PM   #1 (permalink)
Default serious problem, help ASAP
whenever i start my PC it reaches till the windows xp loading screen but after that it restarts again and same thing happens.
can anyone help me with it?
thanx in adv.
Tang
imported_tarang is offline
Old 14-05-2006, 09:35 PM   #2 (permalink)
saurabh.sauron's Avatar
Default Re: serious problem, help ASAP
chk ur SMPS fan and RAM. they might be the culprits.
saurabh.sauron is offline
Old 14-05-2006, 09:39 PM   #3 (permalink)
i checked it that all things are fine. any other way out?
Tang
Old 14-05-2006, 10:10 PM   #4 (permalink)
phatratt's Avatar
try to boot in safe mode.the problem could be either with the hardware(ram,smps) or with the os(corrupted)
Growing old is mandatory; growing up is optional.
phatratt is offline
Old 14-05-2006, 10:54 PM   #5 (permalink)
Alive Again...
satyamy's Avatar
try running it in safe mode if dosent solved after that than tell us
satyamy is offline
Old 14-05-2006, 10:56 PM   #6 (permalink)
it happened with my friends comp. it figured out to be virus problem. I had to format the comp to gt it right. it was figured that it was virus coz this happened on his comp twice and the second time the antivirus gave a warning and my friend ignored at and on next restart the problem happened agian. so again formated...
GOOD LUCK...
What if this world really is Matrix?????
Techinator is offline
Old 14-05-2006, 11:37 PM   #7 (permalink)
i tried safe mode but the same thing no improvement
i also did fixmbr and fixboot with recovery consol but no progress
i think it might be virus.
any onther idea?
Tang
Old 15-05-2006, 12:24 AM   #8 (permalink)
any onther idea?
Try disabling the auto restart from System Properties>Advanced Tab>Start and Recovery Settings.
yashved is offline
Old 15-05-2006, 01:31 AM   #9 (permalink)
but i cannot reach till the windows. it reboots just after the loading screen
Tang
Old 15-05-2006, 10:38 AM   #10 (permalink)
vysakh's Avatar
have u installed any bootscreen changer or anything like that ?
or have u edited the boot.ini file ?
Incompatible message format
vysakh is offline
Old 15-05-2006, 10:39 AM   #11 (permalink)
Back to School Mr. Bean !
mod-the-pc's Avatar
@imported_tarang try booting into LKGC ( Last Known Good Configuration ) and let us know
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
mod-the-pc is offline
Old 15-05-2006, 01:22 PM   #12 (permalink)
if it is what i am guessing even LKGC wont work.
while formatting my friend's comp both the times i found that windows xp installer while giving option of partitioning was not able to recognize the file system of C: . it was showing it as unknown. it might be a virus which has corrupted the file system.
what you can do is try installing some small linux distro and try to save your data by mounting your partitions into linux... i hv not tried it but it might work.
Old 15-05-2006, 09:24 PM   #13 (permalink)
no i havent touched anything like boot.ini file
i was doin my normal work and i kept sometin for downloading and left it as it is. after i came back i saw that windows is restarting again and again.
i think of it as virus attack. if anyone can tell me how do i remove it without formating the HDD, i will be thankful ?
Tang
Old 15-05-2006, 09:26 PM   #14 (permalink)
i tried every option in from the screen we get after pressing f8. but the same thing.
and when i try to install OS with XP bootable CD it works fine. it shows 2 partitions i have.
i just dont want to format my HDD.
Tang
Old 16-05-2006, 08:45 AM   #15 (permalink)
ramprasad's Avatar
Check the IDE cables that connect the HDD and mobo, for me that was the problem
ramprasad is offline
Old 16-05-2006, 07:02 PM   #16 (permalink)
Have you tried repairing your installation? Boot with the WinXP CD and select Repair at the second time (the first time is for Repair with Recovery Console, dont go there)... For detailed instructions, check out http://www.michaelstevenstech.com/XPrepairinstall.htm - read instructions carefully there...
As mentioned there, it will be necessary to install updates again after this, so have a copy of SP2 and the latest autopatcher in hand...
Arun
sakumar79 is offline
