Old 14-05-2006, 01:04 PM   #1 (permalink)
readermaniax's Avatar
Default Rdbms...??????
hey ive been told to prepare a chart on "latest RDBMS software’s" i duno wat to do .. as i dun know WTF is RDBMS .............can u plz help me with the project
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 14-05-2006, 01:44 PM   #2 (permalink)
abracadabra's Avatar
Default Re: Rdbms...??????
chill pal dont get so angry so soon. i know projects are heavy. u culd hav atleast done a google search at the bare minimum.
RDBMS:
1. Resource Database Management System
2. Relational Database Management System
abracadabra is offline
Old 15-05-2006, 11:34 PM   #3 (permalink)
String Phreak
mediator's Avatar
Well dood...there are lotta softwares/programs on which u can apply DBMS. Plus u can make ur own DBMS like in VB etc. There are new softwares that are created daily. Microsoft access also provides u with DBMS!
The few top ones in which u test DBMS and learn, and which are used commercially are : ORACLE,postgreSQL,MySQL,Micrsoft SQL server !
Outta these ORACLE is used most commercially. PostgreSQL has all the features that are implemented in DBMS standard. MySQL is the fastest in terms of processing etc.
If u wanna learn all about DBMS + compare the above four....IM me ur email and I'll give u the name of the ebook to it!
mediator is offline
