Hi
4 d last 6 months i m using triband nite unlimited plan.
my problem, is there any command which can disconnect my pc at 8 in the mornin.
i was usin this command for the last 2 months in dos mode "shutdown -s -t (time in secs) -f ".
with this command, my pc use to shutdown after that specified time.
but after shutdown, d router and the monitor is on bcoz of d power supply.
and after checkin d mtnl account i find dat until i dont completely switch off the power supply to the router, im gettin charged for it.
for instance i shutdown my pc b4 8 a.m. and i forgot to switch off the supply or got up late in the mornin , say, 8:30 a.m. then im billed for dat time between 8 and 8.30 which usually comes abt 40mb for dat 1/2 hr.
so anybody can plzz help me regardin this.
or thr is no solution for it.
