Old 12-05-2006, 07:26 PM   #1 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Automatic Updates Help
When you install automatic updates, windows asks to restart the comp about every 5 mins or so, right? is there any way to disable that and restart later?
because, just now, i was chatting with my friend, typed a message and just when i was about to press enter the "plz restart" window popped up, with the "restart now" button on focus. i pressed enter and it restarted. had to wait for all the startup to load once again....really annoying...
dheeraj_kumar is offline
Old 12-05-2006, 09:29 PM   #2 (permalink)
Alive Again...
satyamy's Avatar
Default Re: Automatic Updates Help
Why are you taking that much tension when you receive any of this message just press Alt+Tab & switch to your previous work or chat u were doing
satyamy is offline
Old 12-05-2006, 10:25 PM   #3 (permalink)
vignesh's Avatar
You need not press till you done all your work...
vignesh is offline
Old 12-05-2006, 10:55 PM   #4 (permalink)
__Virus__'s Avatar
If you are too indulged in thoughts of typing, and you are not having a look at the screen and typing like a maniac, lots of chances of hitting enter
Indeed there is a way to stop this in gpedit.msc u ahve some option in automatic updates...at job now cant tell u the exact path
__Virus__ is offline
Old 12-05-2006, 11:02 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
the best option available to us is select when automatic updates available notify me and do not download them by this u can install & donload them when ur are free so the diolog box does not disturb u.
regards,
gary
gary4gar is offline
Old 13-05-2006, 08:35 AM   #6 (permalink)
Thanks everyone, especially __Virus__
there is an option in group policy editor.
Local computer policy->computer configuration->administrative templates->windows components->windows update->re-prompt for restart with scheduled installations.
i disabled that and it worked perfectly. thanks once again!
PS: repped you virus
Old 30-05-2006, 12:01 AM   #7 (permalink)
__Virus__'s Avatar
opss!!!! thanks... dint see it..
