Old 12-05-2006, 11:22 AM   #1 (permalink)
khansdream's Avatar
Exclamation PPT to AutoPlay CD
Hi Friends,
I want to create a Auto Play CD Presentation. I don't have Flash or Dreamweaver so I created a presentation in Power Point.
What should I do with my PPT presentation to create a Auto Play Presentation in a CD.
Can I convert .PPT to a Auto Play supporting format.
Regards
khansdream is offline
Old 12-05-2006, 02:23 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: PPT to AutoPlay CD
U need following s/w:
1st AutoRun Express
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 13-05-2006, 06:35 PM   #3 (permalink)
khansdream's Avatar
1st AutoRun Express
I used the s/w but it opens my Presentation File in Power Point. I want to run Slide Show automatically when CD was insert without any trace of Power Point. Is it possible????
Or is there any way to convert PPT file to Flash.
Please Help.....!!!!!!!!!
Old 13-05-2006, 10:31 PM   #4 (permalink)
GaurishSharma.com
gary4gar's Avatar
bro for this u need to make *.exe of it
gary4gar is offline
Old 15-05-2006, 04:02 PM   #5 (permalink)
No gary4gar, exe is not required. I made a CD like that which runs the powerpoint presentation automatically as soon as the CD is inserted. All you need is a powerpoint viewer and autorun its exe file through the autorun.inf file....and in that inf file....just give the full path of presentation and the exe.
e.g. your autorun.inf file may look like this:
[autorun]
open=/viewer/viewer.exe abc.pps
icon=whatever.ico
and save this file as autorun.inf in the cd directly. Remember to put the paths of the viewer exe and the pps correctly. For more info and the viewer pm me.....
Krish
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
