Old 22-07-2004, 05:34 PM   #1 (permalink)
NikhilVerma's Avatar
Default How to keep the PC cool?
Guys i want to ask the question that how should we keep the pc cool...
Other than the following methods...
* Extra Fan
* Clean Parts
* Open space
coz even if i don't overclock my p4 2.8Ghz and GeForce4 MX 4000 and i keep my computer cabinet open they seem to get very very hot...
NikhilVerma is offline
Old 22-07-2004, 10:07 PM   #2 (permalink)
the question is how hot ?
if hot beyond normal
then i guess u need to apply another layer of thermal paste
especially if ur computer has crossed the 2 yr mark
No Mercy, No Limits.
theraven is offline
Old 22-07-2004, 11:58 PM   #3 (permalink)
Get custom cooling solutions from thermal take, get a good thermal paste like arctic silver. Use proggies like CPUIdle to lower CPU temps.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 23-07-2004, 12:44 AM   #4 (permalink)
If u need serious cooling try water cooling kits,a watercooling kit with a good thermal paste( arctic silver brand is the best) -- nothing can be better than that. But water cooling kits are very expensive.
It_is_Andrew is offline
Old 23-07-2004, 06:08 PM   #5 (permalink)
Dude if its not too hot (within operational limits) then I suggest you do nothing.
If you really want to see the temperature drop, then I suggest you spend one weekend to do the following:
1. Clean all possible fans in the cabinet. - This improves the fan's performance as the drag due to dust is reduced.
2. Bunch up your cable so that the airflow in the cabinet improves.
3. You can check if the stock thermal layer on your processor has been reduced to just brown dust. If so take a piece of soft cloth and remove this dust from the heatsink. Apply a fresh layer of thermal paste and clamp down the HSF. DarkLord has written a guide on Thermal Paste application. Will post the link here if possible.
Try this and the temperature should go down by a few degrees.
Why fart and waste it, when you can burp and taste it!
SpitefulPentium is offline
Old 23-07-2004, 06:18 PM   #6 (permalink)
i clean my cpu and gpu fan once a week... it really helps keep the temp down..
and hey guys any idea where i can get water cooling kit in mumbai?
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
Old 23-07-2004, 08:21 PM   #7 (permalink)
Where can i get this "Thermal Paste" and for how much??
Old 23-07-2004, 09:20 PM   #8 (permalink)
Thermal paste u'll get it frm a vendor ofcourse if he stocks it. Arctic silver is a bit costly 500 bucks or so....Go to lamington if in mumbai.
Old 23-07-2004, 10:57 PM   #9 (permalink)
Has anyone had any luck in using CPUIdle with AMD Athlon Barton .I found no diff while using that program??
Best regards
Private Martin
Abdul
abdulabby is offline
Old 24-07-2004, 12:13 AM   #10 (permalink)
CPUIdle may not show any changes/improvements while using winxp.cos winxp already uses/follows the method that cpuidle uses to cool the cpu.
The CpuIdle Approach
Under normal circumstances the CPU isn't always active but spends much time waiting for the keyboard, harddisk or CD-ROM. What would be more logical than to turn off the CPU for that period? That's exactly what the HLT machine instruction (Opcode F4) does. Whenever the CPU encounters a HLT instruction the clock is halted and the CPU enters suspend mode until an interrupt, NMI, or reset happens. With the advent of power saving microprocessors like the Cyrix Cx486S the HLT instruction elicits an additional benefit. When "Suspend on HLT" is enabled in the configuration register the processor not only stops on HLT but also enters the power saving suspend mode.
Why Doesn't Windows Do That?
Modern operating systems like Linux execute the HLT instruction in an idle priority thread. This thread is always executed when the CPU is otherwise idle. No additional execution time for HLTing is needed, the CPU will not run slower.
While other operating systems like Linux always used this mechanism, Windows only learned it with NT. But even with NT and following versions it is only enabled when the BIOS and ACPI implementation is recognized by the OS.
Old 24-07-2004, 03:33 AM   #11 (permalink)
alib_i's Avatar
please clear this ..
how do i check that its enabled in my comp .
-Metallica
alib_i is offline
Old 24-07-2004, 10:28 AM   #12 (permalink)
rakee's Avatar
guyz i use AMD Athlon XP 2400.Often i find my system freezing up and its annoying for me to restart again and again.How to overcome this?
The WaNNaB GeeK iNHOUSe
rakee is offline
Old 24-07-2004, 03:10 PM   #13 (permalink)
dude i got the same processor... my pc is fine esp ... that its usually switched on for somewhere around 3-5 hrs a day.. sometimes even more...
i play a lot of games plus only 1 week to go b4 college starts...
which is your memory and os?
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
Old 24-07-2004, 11:34 PM   #14 (permalink)
aadipa's Avatar
i have same proccy 2400+
my pc is always on, may be down for hour or so every 4-5 days
i shut it down only when i make an installation asking restart, or in case of power cut.
and temp remains around 55-60C.
never had a restart due to overheating.
and i have FX5200, a LAN card, 3 HDDs and 1 CD-RW packed in my cabbi
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 25-07-2004, 12:30 PM   #15 (permalink)
Yeah yeah! we know that andrew, but i use CPUIdle with XP and still the temp difference is about 5 to 7 degrees when using CPUIdle. That means my PC runs cooler with CPUIdle. Try it with MBM 5 and u'll know the difference.
Old 02-08-2004, 10:24 AM   #16 (permalink)
rakee's Avatar
my memory is only 128mb ram
rakee is offline
