Old 12-05-2006, 05:42 AM   #1 (permalink)
Default DVD to CD Problem
I have a Microsoft Visual Studio 2005 Pro DVD.I want to convert it into CD.Is there any way of doing this...?
vineetrocks2005 is offline
Old 12-05-2006, 08:28 AM   #2 (permalink)
Ethan_Hunt's Avatar
Default Re: DVD to CD Problem
If thats a data DVD you are talking about then I think there is no way to split the existing Installsheild installation of the DVD.Though you can create and Image of the DVD,Add them to Winrar and split it to equal sizes from there on.Big task but its the only thing that I can think of right now.
V for Vendetta
Ethan_Hunt is offline
Old 12-05-2006, 08:31 AM   #3 (permalink)
Yes it is a Data DVD.Is it the only method or there are any other methods to convert the DVD to CD
