Old 11-05-2006, 11:52 PM   #1 (permalink)
dOm1naTOr's Avatar
Default Convert DVD9 to DVD5?
Which is the best (and faster too) software to convert DVD9 (d layer) movies to DVD5(single layer)?.
Some dvd9 has 4 to 6 movies .I want to burn them to 4.7 gb disc with all the sustitles and scene selection as in the master disc(dvd9).
Moreover some DVD9 with single movies are also them . I want to re-encode or convert it so as to fit in a sinle layered disc with all the features and menu?
Which software is best for that???
It takes very long on Nero 7. Also i dont want to sacrifice quality.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 12-05-2006, 01:08 AM   #2 (permalink)
Dink2cool's Avatar
Default Re: Convert DVD9 to DVD5?
Here ... check out this thread
A Guide to Copying DVD Movies
njoy
Kamehameha !!!!
My blog : dinkarpundir.blogspot.com
The guy who invented the first wheel was an idiot; the guy who invented the other three, he was the genius.
Dink2cool is offline
Old 12-05-2006, 09:11 AM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
DVD Shrink is your best bet! It has the best quality and is also fast!
kalpik is offline
Old 16-05-2006, 01:25 PM   #4 (permalink)
Use AVI2DVD! Its a great tool and gives great quality.
upendra_gp is offline
Old 17-05-2006, 10:58 AM   #5 (permalink)
try DVD decryptor . it is said that it reduces dvd9 to dvd5 with almost no reduce in quality . i dunno abt its speed .
sagargv is offline
Old 17-05-2006, 11:15 AM   #6 (permalink)
Brat-Man
Posts: n/a
THe Best Bet is to Convert it into XviD..
You Can Fill up a 4.34 GB DVD with 6 Movies (of Each 700MB)
Old 17-05-2006, 01:14 PM   #7 (permalink)
DVD SHRINK is the best solution.
You can reduce the file size further by converting the files to Xvid but you wont have chapters.
You can have subtitles though.
Bye
- Amol Sarode
amolsarode is offline
Old 17-05-2006, 01:46 PM   #8 (permalink)
Wandering in time...
Ankur Gupta's Avatar
can a dual layer movie dvd be burnt on to a single layer movie dvd?
if yes hw and which software has to be used?
Integrate Yourself With The Latest Happenings.....
www.ankur-gupta.com/blog
Ankur Gupta is offline
Old 22-05-2006, 01:08 PM   #9 (permalink)
use nero recode 2 which comes bundled up with nero7
and it will work just fine with your pc configurations!
jaskaran singh
jaskaran singh is offline
