Old 11-05-2006, 04:39 PM   #1 (permalink)
maharajadhiraj's Avatar
Default .rmvb converter
Hey guyz I can't get any software that will convert .rmvb files to .avi or .mpeg format PLS help!!!!!!!
maharajadhiraj is offline
Old 11-05-2006, 11:14 PM   #2 (permalink)
Default Re: .rmvb converter
try out SUPER >>
http://www.erightsoft.com/SUPER.html
see if this works
grinning_devil is offline
Old 13-05-2006, 10:33 AM   #3 (permalink)
Unhappy Re: .rmvb converter
Nope, it isn't working grinning_devil. Anyways, thanx for the suggestion.
Old 14-05-2006, 09:32 AM   #4 (permalink)
although don't get a single software for it, i know a method to convert rmvb to avi
for it u need to have virtualdub mod, avisynth.
i don't remember the whole procedure, gotta search for the saved page in my old pc.
i will reply u later.
keep it cool
nd4spd is offline
Old 14-05-2006, 09:23 PM   #5 (permalink)
Thumbs up Re: .rmvb converter
Hey boss, that is EXACTLY what I need. PLEASE look for as fast as you can. Thnx in advance....
Old 15-05-2006, 01:28 AM   #6 (permalink)
here it is
first: make a notepad file in the same folder in which u have the file to be converted. (be sure to name the notepad file as the same as the file to be converted, i.e if u want to convert the file called "CD1.rmvb" rename the notepad file to "CD1.avs", .avs is the extention of the file.)
second: now open the "CD1.avs" file in notepad and write
DirectShowSource("D:\movies\CD1.rmvb", fps=29.97, convertfps=true)
here it is assumed that the file to be converted is placed in "D" drive, under "movies" folder.
now install avisynth v2.56 and virtualdub mod 1.5.10.2 ( i don't know about other versions but i used them) & realalternative 1.4.7
now just open the virtualdub mod open the file "CD1.avs"
go to videos\compressions, and select the compression codec ( i used Divx)
goto streams\stream list, right click on the "source", select full compression mode, then again right click on it, now select "compression..", and choose which ever audio compression u want ( i choose "mpeg layer-3", now choose the bitrate, and say ok.
if u want more mp3 bitrate options (such as 192Kbps, 44000Hz, stereo or even more download LAME mp3 converter)
so after u set all the parameters, just go in "file" tab, and click on "save as", specify the location, give file name, OK.
thats all, tell me, if u want any more help.
keep it cool
nd4spd is offline
Old 16-05-2006, 01:09 PM   #7 (permalink)
Thanx a lot pal. I haven't tried it yet, but shall do so shortly. Reply to you after I try it out. THANX anyways for your troubles.
Old 16-05-2006, 01:45 PM   #8 (permalink)
is this avi file in VCD format
coz i want to convert rmvb to avi and then burn to CD as a video CD which can be played in CD players
chota_rod_waala is offline
Old 23-05-2006, 10:14 PM   #9 (permalink)
mr. chota
if u want to convert rmvb to vcd, u can convert rmvb to avi by the method i told u, and then convert the avi to dat file, by any other software.
keep it cool
nd4spd is offline
