I have installed POP T2T on my PC by mounting the disk image (using DAEMON tools) but when I run it, it says tht i need to insert d game CD n try again....
the most common solution to this problem is to disconnect the optical drives but this is a very time consuming method which requires me to open the cabinet again n again so i want to know if there are any other methods with which i can run the game properly?? If yes, then plz guide me through the whole process as to how i can run d game. Thanks.
