Old 12-11-2004, 04:54 PM   #1 (permalink)
Default Which mp3 player should I buy
I want to buy a flash memory based MP3 player. The capacity should be more than 128 MB, have FM radio...voice recording capability, LCD, etc with a price of around 5000. One of the eligibles is Ennyah DS 601 having all the above at 4200. Please help me!
billgates is offline
Old 12-11-2004, 05:32 PM   #2 (permalink)
gxsaurav
Posts: n/a
U better look at the chinese mp3 players in the market as no branded one is available for Rs 4200 with more then 256 MB memory
if possible streatch your budget & get a 512 MB one with AAC or WMA capability
Old 12-11-2004, 05:49 PM   #3 (permalink)
Has anyone here tried out those cheap Chinese products ? Do they have any shortcomings in performance and/or reliability ?
pimpom is offline
Old 12-11-2004, 05:59 PM   #4 (permalink)
vysakh's Avatar
no reliability for chinese products (the cheap ones)
Incompatible message format
vysakh is offline
Old 12-11-2004, 06:11 PM   #5 (permalink)
Better get yourself a branded one.
Don't trust these cheap chinese products.
Simple things are to simple too understand.
Prashray is offline
Old 12-11-2004, 11:48 PM   #6 (permalink)
try baazee...
best place to buy right now for MP3 players since the big brands have not launched their range of prods officially
baasha is offline
Old 13-11-2004, 07:53 PM   #7 (permalink)
Let the music play.....
djmykey's Avatar
hey i saw a chinese cd mp3 player that guy had got it frm darjaling. it was using a mp3 cd it used to spin the cd extract some 80 seconds of the somg store it then stop spinning the cd and play the song now how cool is that.
djmykey is offline
Old 13-11-2004, 09:57 PM   #8 (permalink)
nuhting unusual abt tht...all cd players use tht tech...essentially to save the battery...after reading the song for a while it kinda stores the remaining song somehow and the doesnt read the cd anymore ...if u dont skip the songs often, the battery lasts really well...
baasha is offline
Old 15-11-2004, 02:27 AM   #9 (permalink)
im not sure abt prices...but a creative mp3 player should b a good choice....personally, i would recommend an ipod if u did not have a budget constraint.....and u can get 1 with expandable memory so that u can always add memory cards and store more songs...
Nemesis is offline
Old 16-11-2004, 11:01 AM   #10 (permalink)
Enyyah players sound good. Also try searching the forums there were threads on this topic b4.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 16-11-2004, 11:45 AM   #11 (permalink)
This one might just fit your needs as well as your pockets.
X-Micro Eva Audio Player
www.Oobertech.net
digen is offline
Old 20-11-2004, 11:22 PM   #12 (permalink)
You can buy the Panasonic SV-AS 10, a 2megapixel camera with mp3 playback. It supports SD Memory Card. It costs around 10k in the grey market and if u want bill it will cost 2-3 thousand more.
aakash12 is offline
Old 21-11-2004, 11:41 AM   #13 (permalink)
SV-AS 10 is not 2 MP. Its just 0.35MP and max supported resolution is 640x480 and its now officially discontinued by Panasonic.
But it does support MPEG4 recording,AAC, MPEG 2 Audio, G.726, MP3 support.
C2D E6600 L626A195 @ 3.42Ghz 24x7|Asus P5N32-E SLI|Crucial Ballistix DDR2 1000|8600GT|4x320GB Hitachi|SBlive 24bit|OCZ Gamextreme 700Watt PSU|Ultra 120 Extreme|Viewsonic VX2025WM 20.1'' widescreen LCD
funkymonkey is offline
Old 28-11-2004, 01:34 PM   #14 (permalink)
Sinnet's Avatar
hello ppl
as for bazee.com <--- this place is shite !!
if u want something go buy it directly from the market
and as for MP3 players buy branded
as the rule applies "YOU GET WHAT YOU PAY FOR"
enjoy
sInNeT
Intel Core 2 Quad Q6600, 2GB Transcend DDR-II 667, Hitachi 320GB + 250GB SATA II, Sapphire ATI Radeon HD2600XT, ASUS P5B-Deluxe WiFi AP, Logitech G15, Philips 201B4......
Sinnet is offline
Old 05-12-2004, 02:53 PM   #15 (permalink)
Chech out these[url=http://dms-world.com/products.html}Dms players [/url]had seen them at an xibition in mumbai.
They r cool the DMS6603 can b used to read ebooks in text and also has inline fm recording.
The sound is good enough at 6k
beyondthegracefgod is offline
