Old 10-05-2006, 10:07 AM   #1 (permalink)
Default Writing ISO files to multisessioned CD..Is it possible?
Hello All...
Can anyone tell me whether theres any way to write an ISO file to a multisessioned CD...??
The reason I want to try this out is that I have quite a few ISO files which are hardly 3 to 30 MB in size, & I dont feel like burning them on altogether new disks...
Also I tried using softwares like ISO buster, but then the contents of the ISO file when viewed through it are different from the contents when the file is burned onto a CD...
Is there anyway in which I can directly install a software in an ISO file without burning it onto a CD??
Looking for replies...Thanks in advance...
HK
h_kunte is offline
Old 10-05-2006, 11:36 AM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: Writing ISO files to multisessioned CD..Is it possible?
as u haved used iso buster i will tell u extracted the the image file with iso buster on the hard disk.then do what u want whether burn it or run setup of it.
gary4gar is offline
Old 10-05-2006, 11:47 AM   #3 (permalink)
champ_rock
champ_rock's Avatar
if it contains info about boot options and something like (linux) that then it cannot be done on a mu;tisession disc.... . otherwise if i just some game or something then u can extract it and burn like any normal forlder...
Registered Linux user number 400618
champ_rock is offline
Old 10-05-2006, 12:13 PM   #4 (permalink)
yeah u can do the same what garygar said ..
NagpurDaMunda is offline
Old 10-05-2006, 04:11 PM   #5 (permalink)
The Researcher
You can do two things:
1. just write the iso files just like any ordinary data. But you will not be able to boot from this cd if the iso's are bootable.
2. mount a virtual drive with alcoholv120 or roxio or virtual cd and mount the iso file on it. You will now be able to run the programmes as if you are running actually from the real CD-rom. This method also is not suitable for bootable images.
Ramakrishnan is offline
Old 10-05-2006, 04:19 PM   #6 (permalink)
royal's Avatar
Thumbs up Re: Writing ISO files to multisessioned CD..Is it possible?
maybe u can extract the contents with WinRar and write them as data cd
royal is offline
Old 10-05-2006, 10:36 PM   #7 (permalink)
adit_sen's Avatar
in short - yes. you can burn iso files to a multisession cd. just burn them as you would normally burn files on a data cd
peace...
aditya
AMD 4400+ X2; Compaq Presario M2202TU; Dell Inspirion 500m; Windows Vista Ultimate
adit_sen is offline
Old 11-05-2006, 12:50 PM   #8 (permalink)
digiFriend's Avatar
if you don't want to boot from it,go for normally multisession burn.(bootable cd are not multisession) )
you never know what you can do until you try
digiFriend is offline
