Old 09-05-2006, 12:17 PM   #1 (permalink)
Exclamation want a confirmation about iso burn
ok I have downloaded a DVD iso image , but I have only CD writer in that pc so can I use cut the image into some 700mb and write to 3-4 Cds then combine it to one dvd again later? will that be OK ?
reddragon is offline
Old 10-05-2006, 08:28 PM   #2 (permalink)
yrana2002's Avatar
Lightbulb Re: want a confirmation about iso burn
If you are going to use the downloaded DVD ISO image on your pc itself, i suggest you use a Daemon Tool such as Alcohol 120%.
These tools set up a virtual CD/DVD drive on your pc, where you can mount/unmount various images.
However, if you are going to use it somewhere else, then you can probably extract the contents using Isobuster, and then burn those contents into seperate CDs.
Another alternative would be to split the image, like you said, into different parts using a Splitter Software, burn them to CDs and later rejoin them to use them.
Search on www.download.com for these softwares.
Savvy
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 10-05-2006, 09:06 PM   #3 (permalink)
Default Re: want a confirmation about iso burn
my problem is somewhat same .the problem is that it is a DVD iso image of 3.4 GB and that pc contains
only CD-RW so what to do?
hellomotto is offline
Old 10-05-2006, 10:50 PM   #4 (permalink)
nishant_nms's Avatar
Use WinRAR to split the image in size of 700MB and burn them. U can later extract them to get the actual image
nishant_nms is offline
