Old 12-11-2004, 01:48 PM   #1 (permalink)
Default Pls Help Me out as I feel, i have been cheated
My computer BIOS shows 512MB(400MHz) but at POST I get the message that DDR 333 (Operating in single channel dynamic paging mode). Which one is supposed to B true. Cant I use the full 400Mhz of the system memory. Pls help!!!
skeleton_of_beelzebub is offline
Old 12-11-2004, 02:39 PM   #2 (permalink)
if ur using pentium core below 533 mhz then ur ram will automatically run at ddr333
i need a 533 or 800mhz fsb processor to make it run at ddr400
No Mercy, No Limits.
theraven is offline
Old 12-11-2004, 03:52 PM   #3 (permalink)
well even 533 MHz CPU will use 333Mhz.
Well it depends on how it is configuered in bios.
The boot screen will report the wat its configuered andnot actiual hardware.
If in advance settings its configuered to run at 333 Mhz it will report 333Mhz at boot screen.
Which motherboard you have and how many memory chips you are using?
C2D E6600 L626A195 @ 3.42Ghz 24x7|Asus P5N32-E SLI|Crucial Ballistix DDR2 1000|8600GT|4x320GB Hitachi|SBlive 24bit|OCZ Gamextreme 700Watt PSU|Ultra 120 Extreme|Viewsonic VX2025WM 20.1'' widescreen LCD
funkymonkey is offline
Old 12-11-2004, 05:07 PM   #4 (permalink)
read before u post man .. HE has configures it as 400mhz in the BIOS ...
anyways there was a discussion on this kind of
i found th elink for u
here u go
http://www.thinkdigit.com/forum/viewtopic.php?t=9552
theraven is offline
