Old 12-11-2004, 08:00 AM   #1 (permalink)
Default slow pc??
I am using Windows 98/XP:
Recently my computer's (win 98) startup and shutdown process has slowed down drastically. It takes over 1 minute to shut down, where as Win XP is working fine. I recently installed a 256 MB RAM to my computer.
Can anyone suggest what could possibly the reason and solution to this problem.
Work consists of whatever a body is obliged to do, and play consists of whatever a body is not obliged to do.
hsnayvid is offline
Old 12-11-2004, 08:17 AM   #2 (permalink)
The Photoshop Guy
cooljeba's Avatar
hmmm try to clear up unwanted programs from the strtup list, scan disk, defrag it, clear of temp file from the windows\temp folder.... hmm... try a virus scan..... uninstall some old un used programs.... try cleaning registry with registry cleaner etc etc. w8 fo rreply to get more idea's
..:: peace ::..
Jeba
cooljeba is offline
Old 12-11-2004, 09:11 AM   #3 (permalink)
it_wasnt_me : post ur HijackThis log here
suhas_sm is offline
Old 12-11-2004, 03:54 PM   #4 (permalink)
NikhilVerma's Avatar
Install Windows ME dude!!
Way better than 98....
NikhilVerma is offline
Old 13-11-2004, 10:20 PM   #5 (permalink)
..:: peace ::..
Jeba
scanned disk
deefraged it
cleared the temp files
virus scanned
uninstalled several progs
just a few days ago.
will try registry cleaner soon.
hsnayvid is offline
Old 14-11-2004, 12:21 AM   #6 (permalink)
try to clear up unwanted programs from the strtup list, scan disk, defrag it, clear of temp file from the windows\temp folder, try a virus scan..... uninstall some old un used programs.... try cleaning registry with registry cleaner etc etc. w8 fo rreply to get more idea's
use xp and hibernate facility
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 14-11-2004, 12:58 AM   #7 (permalink)
@indyan me to think ME was better than 98
atleast my experience was
i experienced a more stable OS and less Blue screen errors ...
but i soon enuff shifted to win 2k and then xp
the transition stages were quite short
No Mercy, No Limits.
theraven is offline
