Old 12-11-2004, 06:34 AM   #1 (permalink)
Default shut down timing
hi friends,
what should be the ideal time for shutting down win xp.i feel it takes much more time in shutting down after up grading to win xp sp2.what r the factors inluencing the shut down speed?
mahendran is offline
Old 12-11-2004, 08:22 AM   #2 (permalink)
The Photoshop Guy
cooljeba's Avatar
hmm....
factors that depend on shutdown is the number of process running in the memory... 'casue the OS needs to close them one by one to procced to shut down the system!! the more processes running the more delay.
..:: peace ::..
Jeba
cooljeba is offline
Old 12-11-2004, 09:00 AM   #3 (permalink)
Also some programs not responding can cause a delayed shutdown.But you can always execute "end task".
www.Oobertech.net
digen is offline
Old 12-11-2004, 09:06 AM   #4 (permalink)
not be more than 6-7 seconds i guess if ur pc is finely tuned ...
what say ??
suhas_sm is offline
Old 13-11-2004, 11:11 AM   #5 (permalink)
Default shuting down time
my pc takes about 45 seconds for shut down?how to reduce this time?
Old 13-11-2004, 12:57 PM   #6 (permalink)
vysakh's Avatar
if ur CPU usage was full for some time before shutting down, it will take longer
Incompatible message format
vysakh is offline
Old 13-11-2004, 07:17 PM   #7 (permalink)
Default Re: shuting down time
which os u have ??? u might be having a real scrambled pc it seems!
use softwares that optimizes OS such as system mechanic or something. kepp them free from spywares n adwares n viruses too.
suhas_sm is offline
Old 13-11-2004, 08:04 PM   #8 (permalink)
shutdown time depends on a lot of things ...
cpu usage ... np. of programs runnin ... etc
also it keeps increasing as u use ur system ...
also dependent on disk fragmentation
also windows waits a certain time to allow apps and services to shutdown automatically
use THIS tweak to lessen it .. (win xp)
there is also something like waiting to flush the virtual memory or somethign
i forgot the reg tweak but there are software available to do this ..
check the following links .. it'll help u shut windows down faster
however i must warn u ... it is not recommended to use these software as it disables flushin of virtual memory .. which isnt recommended either
but it does its job well
http://www.webmasterfree.com/2004/0528.html <=== a utility called super fast shutdown ... try it out
http://www.nonags.com/nonags/shutd.html <=== some more useful software with description
No Mercy, No Limits.
theraven is offline
Old 13-11-2004, 08:25 PM   #9 (permalink)
9 seconds is what i get.
perk_bud is offline
Old 14-11-2004, 12:22 AM   #10 (permalink)
just use hibernate facility of xp
EVERY QUESTION HAVE PERFACT ANSWER
AND NOTHING IS IMPOSSIBLE
vinaypatel is offline
Old 14-11-2004, 12:40 AM   #11 (permalink)
guys there is a setting that cleans up the swap (write 0 on entire swap space) if this is enabled then winxp takes long to shut down.
**** happens
pradeep_chauhan is offline
