Wow....whats this new disease that relates adware with madness
Anyways, this is how u must go abt it-:
>>Download anti-spy software like Spyboy-S&D ,AdAware, Windows Malicious Software removal tool(April release)
>>Then update these two with the l8est definitions
>>Re-boot(in safe mode if u like) and run scans by all of them one after the other
>>after all the spyware has been removed, reboot again and see if u find any problems
>>if yes, then scan once again with them
>>if no, then download and install a PROPER firewall like Outpost or Zonealarm or BlackICE. Most of them have inbuilt spyware guard.U may also want to get Windows Defender Beta 2.
>>Also, for extra precaution, just turn on the Immunization feature of Spybot
>>If u use IE, then make sure u have IE6 SP1 and winXP SP2 installed and if FF, then make sure u have the Ad-block Filterset extension installed. This extension makes FF the safest browser
>>Though all these will be able to detect the potential threats, the security primarily depends on the user's judgement as to what must be browsed during internet sessions
This should be enough to prevent u from going mad. IAnd dont forget to keep ur anti spy software up-to-date
PS: Yahoo-antiSpy is hopeless, though it is able to detect the spyware, it is rarely able to remove them
