Old 11-11-2004, 09:46 PM   #1 (permalink)
Default NTFS encryption
i recently formatted and reinstalled windows XP pro on my computer.now i cannot access the encrypted files on the NTFS partition on the drive.i had used just the basic encryption that XP provides with NTFS.how do i go bout recovering the files??
FleaPython is offline
Old 12-11-2004, 12:42 AM   #2 (permalink)
You can only access the encrypted data if you saved the encryption key. I doubt you did that because otherwise you wouldn't be asking this question. Without the key there is no way to access the data.
drvarunmehta is offline
Old 12-11-2004, 10:01 AM   #3 (permalink)
King of my own Castle
freshseasons's Avatar
I'm sorry FleaPython but drvarunmehta is right......There is no real way to get that Data back....you should always save the Encrption key ...
I guess that Encryption feature in windows Xp is with a purpose...
freshseasons is offline
Old 12-11-2004, 08:26 PM   #4 (permalink)
where is the 'encryption key' neway??
prankzter is offline
Old 12-11-2004, 10:18 PM   #5 (permalink)
Default U Should have a Certificate ya.
Uhh Now Dont misunderstand me
As far as I know, While doing encryption only Try to export a certificate ya.
So that even u format, By Using that certificate.. U can recover..
I will advice as - Use PGP For encryption..
Download from - www.pgp.com - ItS Free
Hey Know what ! Use Winzip v9.0 , Coz the new version supports Password protection As well as Encryption.too
U can have simple Winzip Encryption As well as Hi-Fi 128 & 256 Bit Cipher Encryption too..
Enjoy
PraKs is offline
Old 13-11-2004, 12:45 AM   #6 (permalink)
i still have the WINDOWS and the PROGRAM FILES folders from the old installation. Is there anyway i can extract the certificate from them?
- by Krow
