Re: Cartridge Refill...sahi process
hp cartridges are not meant for refill, so the "ink level" will nnever increase even if the ink is full.....
also, i think u hve injected more ink than it can hold because of which the ink is oozing out....to solve this try to print some test pages and then wipe the head with a tissue paper... i think then it should be fine....
Amkette black e-fill Inkjet refill system.- i did not know such a thing existed... can u please post a review mentioning its details functioning, prise etc. from ur experience
Registered Linux user number 400618
