04-05-2006, 07:24 AM
Bios Update
I have an old Compaq Presario with Abit BD-70G motherboard.I want to upgrade its BIOS.Currently I have Award Phoenix 6.0 Bios.Can anyone tell me where i can found the BIOS update of this motherboard.
Thank u
04-05-2006, 10:46 AM
Re: Bios Update
http://www.award-bios.com/index.cfm
But be careful while doing this... Updating the BIOS can be a nasty bussiness...
04-05-2006, 10:55 AM
Back to School Mr. Bean !
Re: Bios Update
I think you'll be charged for BIOS updates from above link. Better option would be to get it from Abit's ( http://file.abit.com.tw/pub/download//fae//bg7m8w.exe) / Compaq's website
Desktop: P4 2.8E, Intel 865GBF, 512MB Hynix PC3200, Samsung SV1204H 120GB, Samsung SW-248F, Creative Inspire 4400, Samsung 793MB, Compro PVR/FM, WinLIRC
Laptop: HP Pavilion dv8210us
13-05-2006, 02:50 PM
The Researcher
Re: Bios Update
Be very very careful. One wrong step can make your motherboard unusable.
14-05-2006, 06:49 PM
Re: Bios Update
i dont recommend BIOS update. make sure u're using the correct updater and version of it too . I wud suggest u to get advice from compaq before proceeding, Corrupt bios can render ur mobo useless .and i dont like the idea of sending mobo for rma and waiting for a long time.
Besides , why d'u wanna do this ??
15-05-2006, 10:58 AM
Re: Bios Update
There's always a way out (the recovery BIOS I mean and I've recovered from a few bad flashes) !!! So lets not frighten Vineet
15-05-2006, 11:16 AM
Re: Bios Update
As long as you follow the instructions properly and the power dosen't go off while updating, there's no reason to believe that something will go wrong.
07-06-2006, 02:19 PM
Re: Bios Update
do it if you know what u r doing
Inter core 2 duo E 6750
Biostar TP35D2-A7
2X1 GB PC 6400 DDR2 @ 820 Mhz
NVIDA GForce 8600 GT
320 GB WB HDD & 120 GB Segate HDD & WD 400 GB Ext
Sony DVD Writer
Asus VW192T 19" WS LCD
07-06-2006, 02:34 PM
Your Maker.
Re: Bios Update
Oh..its nothing so scary. Just make sure u KNOW how to update a BIOS specific to ur system...and make sure u use a proper flashing utility.
“Talent is a flame, but genius is a fire.”
07-06-2006, 04:11 PM
In Pursuit of "Happyness"
Re: Bios Update
Ill just say one thing: "Dont fix it if it ain't broke.."
07-06-2006, 09:10 PM
Re: Bios Update
He was asking about an older board and so your advice is very relevant.
But in case of modern Mobos like A8N-E for example, one can update without any fear since in case something goes wrong, the original one can be restored using the Mobo CD only. And the updating can be done from windows itself, either from a downloaded file or directly over the Net. I have already updated it thrice, each within minutes and never facing any problem or having to resort to recovery.
V.Prem Kumar
08-06-2006, 07:08 AM
Re: Bios Update
Yeah.. true.. But Never update from windows. Thats even more dangerous. The manufacturer's themselves ask not to update from within windows. And my advice applies to all boards, new and old. Sometimes a BIOS update creates more problems..
08-06-2006, 08:29 AM
Re: Bios Update
I have updated from windows only and never had any problem. And in the Asus site, I have not seen them discouraging it. Also if it is so, why should they make such a provision in the Asus Auto Update Utility?
V.Prem Kumar
08-06-2006, 09:15 PM
Re: Bios Update
I don't think there will be a problem if you update the BIOS from Windows.
As long as you follow the rules strictly, there won't be any problem.
Always update the BIOS when it necessary (to fix some problems).
09-06-2006, 06:58 AM
Re: Bios Update
13-01-2007, 11:53 AM
Re: Bios Update
Hi, I am also in need of a similar BIOS update like Vineet. Someone was asking why would we need a bios update.
As the product reaches end of life, the manufacturer does not support. In my case I want to make my Bios boot from a USB 2.0 DVD ROM drive, but I am not able to find the USB option in my Bios CMOS setup utility. So an upgrade becomes necessary.
regards
Search this Thread |
