Re: suggestion needed...urgent
buy PATA as you r in urgent need. pata disk will be also be supported by any new motherboard(as long as cd/dvd drive are pata,there will be pata support in newer motherboard). practical difference in data speed is negliable between pata and sata1.(buying new mother board will not solve the problem as your RAM, processor may not be supported by new motherboard.)
true hard fact:there is nothing like update in hardware,design change is so rapid and newer model carry premium price.
you never know what you can do until you try
