HD-COPY - Fast diskette copier and high capacity formatter.
[updated 2004-08-07]
From the docs...
HD-COPY is the fastest copy-program I know (and I know many) --- there's definitely no faster one. You can also use it to format disks at various formats (from 720 Kb to 1.764 Mb in this version of HD-COPY), which is faster than DOS' FORMAT and produce s less errors.
The following DD formats are supported:
* 320 Kb, 360 Kb, 720 Kb; "special" DD formats: 400 Kb, 800 Kb, 820 Kb and similar
The following HD formats are supported:
* 5 1/4 inch drives: 1.2 Mb, 1.44 Mb, 1.48 Mb and similar
* 3 1/2 inch drives: 1.2 Mb, 1.44 Mb, 1.48 Mb, 1.72 Mb and similar
Note: To use non-standard disks (i.e. 5 1/4 disks with more than 1.2 Mb or 3 1/2 disks with more than 1.44 Mb) outside HD-COPY, you have to install a TSR program like FDREAD (included), because the DOS/BIOS doesn't like disks with an unusual number of s ectors. HD-COPY itself doesn't need FDREAD, since it has its own routines to handle special formats.
Author: Oliver Fromme (1995) Germany. Cardware.
download hdcp20ae.zip, in English (81K), or/oder hdcp20ad.zip, auf Deutsch (101K)
http://short.stop.home.att.net/freesoft/diskutil.htm
