Old 10-11-2004, 07:30 PM   #1 (permalink)
Default Please help me in upgrading
Hi
I am planning to upgrade my pc (Athlon XP 1700+, asus mobo). I am a casual gamer and a performance freak. please help me to upgrade.
1) the very first thing, is it worth upgrading NOW. i hear that intel XE edition of processors with 1 ghz of fsb are round the corner.
2) if i upgrade now should i go in for AMD 64 or intel (915/925)
3) whats are the current market prices of AMD's 64 Fx series of processors and their compatible boards.
4) if i go in 4 intel should i buy an intel original or a chipset board (from asus etc)
5) Are PCI express based graphic cards of any use. Do they provide any performance boost over normal 8x cards.
geek is offline
Old 10-11-2004, 07:49 PM   #2 (permalink)
vysakh's Avatar
1..yes, it is worth upgrading now
2..for ur games i would recommend AMD 64
3..oops!
4..i recommend to buy the original
5..Yes they are faster
Incompatible message format
vysakh is offline
Old 10-11-2004, 09:40 PM   #3 (permalink)
@geek dont make multiple posts to get common info
http://www.thinkdigit.com/forum/view...?p=93219#93219
u couldve just posted it there
its not worth upgrading to an intel now ... cuz even the 64 bit processors are lined up
tho this will take half a year to come in
tho u CAN wait for the nforce4 mobos supporting the amd64 processors ... they should be just ard the year
again like i said go for amd 64
amd 64 mobos will cost u 5650 for a good asus build
and processors starting from 8600 for amd64 3000
any processor u go for .. i always suggest ASUS as a mobo .. its the best ... more stable and packed with features
pcie does offer a performance boost
but it wont be noticable if u get a low end card
to notice this diff as of RIGHT NOW .. u need the top of the line cards
even the x600 will not show u much of a diff over the 9800 pro
the x700 might have an edge tho
right now pcie is just nascent ... it'll take time to settle inm
anyways if ur going in for AMD now .. forget abt pciE .. no amd board supports PCIE right now ..
like i said .. wait for the nforce4 mobos .
No Mercy, No Limits.
theraven is offline
Old 10-11-2004, 09:48 PM   #4 (permalink)
wait!!!!!!!!!! do not upgrade now.
**** happens
pradeep_chauhan is offline
Old 11-11-2004, 12:27 PM   #5 (permalink)
pradeep u said that i should wait. can u let me know the reason. is it intel 64 or something
geek is offline
Old 11-11-2004, 01:59 PM   #6 (permalink)
dude the Nforce4's r going to be released!!!
and then the prices of 939 proccies will cum down!!
the 939 CPU's provide a good polish the the A64 chip
nikhilesh is offline
- by Krow
