Old 01-05-2006, 04:41 PM   #1 (permalink)
sagar_coolx's Avatar
Default strange files.
hi guyz. i have win xp with sp2 installed on my 160 gb segate sata hdd with 4 ntfs partitions. but on each partitionh,there are some strange files as shown in the picture.
what are these?are they created by vius/spyware?how can i delete or hide them?
sagar_coolx is offline
Old 01-05-2006, 04:59 PM   #2 (permalink)
ashfame's Avatar
Default Re: strange files.
They are system files, i think of system restore.
U can hide them my going to folder options>view> and make sure hide system protected files is checked.
That should solve ur prob.
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 01-05-2006, 05:08 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
download and use 'ccleaner'. if it is junk, it will be removed.
also scan ur pc with adaware plus ewido, in safe mode. if its malware, it will be detected.
if u still feel worried, post ur hijackthis logfile here or at www.hijackthis.de for analysis.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 01-05-2006, 05:54 PM   #4 (permalink)
prasad_den's Avatar
Do not delete them.. They are files used by the System Restore..
prasad_den is offline
Old 01-05-2006, 06:19 PM   #5 (permalink)
I think they might have been created by System Mechanic... Did you install that software? If you no longer have it, you can delete it I think...(But perhaps you may want to create a System Restore Point before trying this)...
System Restore files are not stored in the root directory AFAIK, there is a hidden folder called SystemRestore or something like that...
Arun
sakumar79 is offline
Old 01-05-2006, 06:27 PM   #6 (permalink)
oh yes i use sys mechanic.
but i dont want these files.is there any setting i can change?
Old 01-05-2006, 06:27 PM   #7 (permalink)
ashfame's Avatar
Arun
They are the files of system restore.
Anyone can help explaining the working of system restore??
ashfame is offline
Old 01-05-2006, 06:27 PM   #8 (permalink)
Ishan's Avatar
My PC too contain the same type of files, n i am quite sure yhey are of restore files created by system
Ishan is offline
Old 01-05-2006, 10:42 PM   #9 (permalink)
kindly tell me the name of software u used for that picture
amitgg is offline
Old 02-05-2006, 08:45 AM   #10 (permalink)
ashfame's Avatar
I also wanna name of the soft u used to take snapshot
ashfame is offline
Old 02-05-2006, 10:10 AM   #11 (permalink)
Ishan's Avatar
it can be done in photoshop easily, but if any other program for taking snapshots of the screen then, tell us.
When was the last time when you did something for the first time?
So many words for the broken heart.....
for world wars. ishangajera.blogspot.com
Ishan is offline
Old 02-05-2006, 01:59 PM   #12 (permalink)
oh,i just pressed ctrl+prt scrn ,pasted and edited it in photoshop.thats it.
Old 03-05-2006, 07:46 PM   #13 (permalink)
c'mon!cant anyone tell how to remove these files?
Old 03-05-2006, 09:01 PM   #14 (permalink)
ashfame's Avatar
Thumbs up Re: strange files.
If ya remove them your system will not be restore completely if u choose to restore it.
Ignore them, its good for u & ur system.
ashfame is offline
- by Krow
