Old 30-04-2006, 08:08 PM   #1 (permalink)
Default Doubt
Hi,
wat does this mean?
->>> Number values should not be enclosed in single quotes, coz implicit conversion may take place for numeric values assigned to NUMBER data type columns if single quotes are included.
Can u plz explain the last sentence , as to how does it convert and to wat?
Think about it!
Trinity is offline
Old 01-05-2006, 07:11 PM   #2 (permalink)
Ishan's Avatar
Default Re: Doubt
I think that if this is an error it would be given by some programming language,
as much as i understood from this is: the numbers should not be written in single quotes (in the field of datatype NUMERIC ) becoz if done so it may consider the single qoute as any operator and some undesired result may come(due to the cals which would occur due to that operator)..
rest i can tell if u give the whole discription.
Ishan is offline
Old 01-05-2006, 07:42 PM   #3 (permalink)
sknowonweb's Avatar
Default Re: Doubt
'2321' => means 2321 is considered as a string, i think u r using a variable which was assigned this type of string for some numeric calculation .
better declare the variable.(such as int , dim..,.. )
a soln may be a=2321 ( instead of a='2321')
ps) Does this error is from a SQL statement
தமிழ் வாழ்க
____________
EVIL : G00D :: YIN : YANG
________
sknowonweb is offline
- by Krow
