Old 30-04-2006, 04:26 PM   #1 (permalink)
maharajadhiraj's Avatar
Default problem with bitcomet
Whenever I start my bitComet, the bar above shows that some download is taking place, although none is. When I resume any download, though they have loads of seeds, they do not run (shows 0kb/s), but the bar above shows the download going uniformly at 8kb/s. What is the problem?????
maharajadhiraj is offline
Old 30-04-2006, 08:41 PM   #2 (permalink)
saurabh.sauron's Avatar
Default Re: problem with bitcomet
the bar shows the incoming bandwidth. it does not show the download speed.
u have to wait patiently for the downloads to start. u might try to forcibly start a download althought that rarely helps.
saurabh.sauron is offline
Old 01-05-2006, 12:24 AM   #3 (permalink)
mariner's Avatar
do u close bitcomet after downloading something? cos if u do so and u dont upload then u r tagged as leecher and the downloading speed decreases drastically.i used to get initially speeds as high as 24 kbps and iused to close bitcomet after that.
then i statred getting slow speeds, so now i keep bitcomet on all the time.
on an average i get 16-18 kbps.
mariner is offline
Old 01-05-2006, 10:14 AM   #4 (permalink)
Total Downloaded: 40.8 GB
Uploaded: 28.6 GB
This proves I m not that bad a leecher
Old 01-05-2006, 11:40 AM   #5 (permalink)
LegendKiller's Avatar
He's right,in fact you gotta wait,to start the downloads,keep the uploading to minimum like 4-5 kbps depending on ur connection...
In the Pic: The Great Sachin Tendulkar
LegendKiller is offline
Old 01-05-2006, 03:16 PM   #6 (permalink)
godsownman's Avatar
The key is patience, sometimes the downloads do take time to start.
Check the %age health of the file. When selecting downloads always look for them in Green as green means that you may be able to successfully complete the download.
Secondly, sometimes the people uploading may not have the 100% file with them.( I am stuck on one download at 96 % with all seeders being stuck at 96 % )
Try it out and I am sure you will get it or re search for it and then start the download.
P.s : I have answered this keeping in mind that you may be facing this problem with only one file.Please correct me if I am wrong.
Thanks
godsownman is offline
Old 01-05-2006, 03:35 PM   #7 (permalink)
Raiden Bee's Avatar
Get this Acceleration patch for BitComet
http://www.softpedia.com/get/Interne...on-Patch.shtml
Raiden Bee
"Nobody's perfect and I stand accused................
....I'm at a loss of words and that's my best excuse"
Heck! no BBcodes in sig! Waa!
The Bee Blogs Here:
http://pooryoungggeek.blogspot.com
Raiden Bee is offline
- by Krow
