Old 29-04-2006, 08:52 PM   #1 (permalink)
In To The World
netguy's Avatar
Question Need hlp regarding working with Virtual Dub
My friend recently gave me this sofware
Virtual Dub 1.5.10
My friend said that with the help of this tool i can fit a whole cinema in to a cd . but he too doesnt know how it works
he showed me a movie made of this thing
can any one help regarding this issue
netguy is offline
Old 29-04-2006, 09:32 PM   #2 (permalink)
ashfame's Avatar
Default Re: Need hlp regarding working with Virtual Dub
Go to this link:
http://ryan.com.br/virtualdub_en.htm
My RIG: C2D 2.0Ghz + Intel965 Mobo + OCZ Matched Pair 2X1GB DDR2 800Mhz + LG L226WTQ 22" LCD + CM 500W PSU + Palit HD 4850 512GDDR3
HOMEPAGE : http://www.ashfame.com | BLOG : http://blog.ashfame.com
ashfame is offline
Old 01-05-2006, 11:51 AM   #3 (permalink)
parthbarot's Avatar
goto www.doom9.org and find tutorial 'virtual dub procedures' there...it is good and fully explained....also all codecs explained there...
need any help regarding video compresion then ask.
i have compressed many video songs + 4 to 6 full movies with this tool..its grt tool...
www.techlads.com
Paarth.
parthbarot is offline
Old 01-05-2006, 12:17 PM   #4 (permalink)
Smile Need hlp regarding working with Virtual Dub
Try Nicky's pages. I've compressed many movies using Virtual Dub. It is by far the best. You'll have probs inthe beginning but once if you rip a movie, then ripping will be a breeze. Jus get the codecs installed and choose the correct bit rate[depending on the quality of movies you want].
rhsarath is offline
- by Krow
