Old 29-04-2006, 08:44 PM   #1 (permalink)
vikasg03's Avatar
Default How can we burn DVD with MPG files
Hi to all group members,
I want to burn video songs in MPG format in DVD, but play as a DVD.
Is it possible. I want to do this in MPG so that i can burn more videos in DVD. How can we burn DVD as a VCD???
I just want to write more more and more videos in DVD and thats why i don't use vob format. is it possible to burn mpg files in DVD but not in data CD.
vikas gupta
vikasg03 is offline
Old 29-04-2006, 09:55 PM   #2 (permalink)
saurabh.sauron's Avatar
Default Re: How can we burn DVD with MPG files
@vikas...
AFAIK its not possible. if u burn them directly, the dvd player will show it as unknown format. if u encode it to dvd format, multisession will be off.
saurabh.sauron is offline
Old 29-04-2006, 10:15 PM   #3 (permalink)
nil_3's Avatar
VCDs are MPEG1 files where DVD is MPEG2. MPEG1 and MPEG2 files differ in resolution and so in file-size. However MPEG1/MPEG2 files are not playable in standalone VCD/DVD player(though playable in computer); they have to be formatted in VCD/DVD which can be done by any standard writing software(e.g. Nero/Roxio). However now-a-days, some standalone players are available in market which can play MPEG files and even DivX files. Try such one.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 30-04-2006, 06:28 PM   #4 (permalink)
hafees's Avatar
If your player supports DivX video, then you can even compress your mpeg files. And you can write 4 near dvd quality movies or 6or7 VCD quality movies in one DVD.
hafees is offline
Old 30-04-2006, 07:05 PM   #5 (permalink)
vikasg03's Avatar
thanks hafees
as u write "..................or 6or7 VCD quality movies in one DVD." This is the actual thing which i want to know HOW??. when i open nero 7.0 and select DVD VIDEO DISK then add option only allow me to add .VOB files and i want to add MPG file. how can i do this . and as u write how can i write 7 VCD quality movies on single 4.7 GB DVD. and also i am only interested to run DVD on computer but wants to write movies as a MPEG so that i can write more movies(6,7) in single DVD.because VOB extension takes double size in comparision to MPEG.
vikas
vikasg03 is offline
- by Krow
