29-04-2006, 08:35 PM
ShaPlus Bandwidth Meter
Hello friends,
I have created a small bandwidth meter which will show the bandwidth consumed for the current session, day and month. Currently it has got only few features, will be adding more later.
You can download it from www.shaplus.com/bandwidth-meter/
regards
ShaPlus
29-04-2006, 08:58 PM
Rubik's Uncle!!
Re: ShaPlus Bandwidth Meter
Thanks for the tool shaplus  . I will try this tool and give you feed back
29-04-2006, 10:43 PM
9437077259
Originally Posted by shaplus
Hello friends,
regards
ShaPlus
Is this software developed by you. And what about Shaplus Dataone bandwidth. Is this also developed by you.
Tell me one thing, how can I affirm that my password is not going to be sent to anyone else through this software. Dont take me wrong, but this is a very important factor before using any new software.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
29-04-2006, 11:37 PM
Pharmaguru
I jsut downloaded it its great , also there is enable/disable ie images feature which is helpfull (hope it works)
Thanks Shaplus
My Photography gadgets :
Nikon D5100 with 18-55mm VR Lens, Nikkor AF-S 50mm 1.8g, Tamron VS 70-300 VC Di
Cullmann NANOMAX 220 Tripod. | Crumpler messenger boy stripes 4000 camera bag :grin:
30-04-2006, 12:51 AM
Coming back to life ..
Yeah I too use it and its the best. I trust the program so use the password one.
Thanks for creating a great software. .. !
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
30-04-2006, 10:16 AM
Bandwidth meter do not need a internet connection to function, so it will work even if you block access to internet for this software using a firewall.
Dataone Bandwidth(password version) requires internet connection since it is retrieving log from Dataone site itself. You can use a firewall to allow this software to connect only to Dataone site or you can check the traffic log to see which are the sites this software connects to.
I will be adding quick option to enable/disable flash also. Enable/disable images will work only for new IE's launched after changing this.
Thanks for all feedback
30-04-2006, 02:34 PM
Just Do It
Cool software.. I've used this before .... Tks for the update.
30-04-2006, 02:40 PM
9437077259
Thanks for the reply! As you said that we can use a firewall to allow this software to connect to Dataone site only, Can you please explain me how can this be achieved. I am using ZoneAlarm 6 as a firewall. Now, how do I configure my firewall for this software.
Secondly, how do we check the traffic log. Please explain.
I know these explanations goes out of topic, but is very important for me to know before I start using these softwares.
Win 7 Ultimate
30-04-2006, 07:12 PM
I personally use sygate personal firewall 5.5. It is not a freeware now but you can download previous freeware version from
http://www.oldversion.com/program.php?n=sygate
When installed, right click on its tray icon and there is "logs-> traffic logs" to see ip addresses each program connects to.
To know which are the IPs that are to be permitted for dataone usage checking, first clear the traffic log and check dataone usage using Internet explorer. Now check traffic log and find out the ip addresses that IE connects when checking usage. Now right click sygate tray icon, choose applications, select Dataone-Bandwidth 2.4.exe , and in the advanced section give these IP addresses as trusted IPs.
If Dataone-Bandwidth 2.4.exe is not in your applictions list then, first use it and when prompted to connect to internet, block it. it will come in the list. Later after trusted Ips are given, remove the block.
Search this Thread |
