Old 29-04-2006, 12:42 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Mpeg error ! ! !
while opening dat or mpeg file i get this error "mpeg import filter: pack synchronization error" ...
i use virtualdub ...
whot 2 do as i wanna convert dat files 2 divx ???
ax3 is offline
Old 29-04-2006, 08:02 PM   #2 (permalink)
slugger's Avatar
Default Re: Mpeg error ! ! !
is d file actualy an *.mpg file or is it just a *.dat file whose ext is changed to *.mpg
in all lielyhood u r trying to feed an MPEG 2 file into VirtualDub. It only supports MPEG-1 u will have to use VirtualDubMod
VirtualDub doesnot support *.dat --> *.avi [DivX container in Virtualdub].
you will first have to convert d *.dat file into an actual *.mpg file using SW like
VCD Gear
http://www.vcdgear.com/
ps :- don't use VCD Cutter, ull face major AV synch issues
http://virtualdubmod.sourceforge.net/
but u still will have 2 convert ur *.dat into *.mpg
slugger is offline
Old 01-05-2006, 11:52 AM   #3 (permalink)
parthbarot's Avatar
if cant open then use virtualdubMod...it mostly opens all the files...
new version of VDUB is more carefull abt quality of input file..if bad frmaes found then it will stop loading the file from there.
so use vdub1.5.10 or vdubMod for that.
www.techlads.com
Paarth.
parthbarot is offline
Old 03-05-2006, 05:31 PM   #4 (permalink)
ax3
ax3's Avatar
dat file is converted 2 mpg using VCD Gear as u suggested ... bt still no luck ... same error ...
help ...
ax3 is offline
Old 04-05-2006, 11:31 AM   #5 (permalink)
parthbarot's Avatar
u need to fix errors from it using some tool which scans video and fix errors and save it as a new file. like divfix does for avi files...
www.techlads.com
Paarth.
Old 04-05-2006, 05:22 PM   #6 (permalink)
ax3
ax3's Avatar
hey parhbarot, can u giveme the site name for divfix ...
ax3 is offline
- by Krow
