Old 28-04-2006, 11:40 PM   #1 (permalink)
hluachawngthu's Avatar
Thumbs up How to remove unwanted fonts?
How can I identify fonts that can be safely deleted
from my system? Plz help.
hluachawngthu is offline
Old 29-04-2006, 12:44 AM   #2 (permalink)
Default Re: How to remove unwanted fonts?
I think you can simply delete the additional fonts(i.e. except the standard ones like Arial and Times New Roman) from the Control Panel itself.....
yashved is offline
Old 29-04-2006, 01:04 AM   #3 (permalink)
SABER RIDER
maverickrohan's Avatar
the only reason anyone removes fonts is to make his sytem slighty faster.....if ur system is so slow that need to come to this level to make it faster..........may the force be with u .........
Anywaz........the above soln is correct.......
Find out Which is The Best Video Codec?....And how to encode video the right way..!!----->>>>> http://www.thinkdigit.com/forum/showthread.php?t=3908
maverickrohan is offline
Old 29-04-2006, 08:04 AM   #4 (permalink)
Its better to backup the fonts before deleting them, then delete the backups about a month later after ensuring there are no problems...
Arun
sakumar79 is offline
Old 29-04-2006, 11:24 AM   #5 (permalink)
digiFriend's Avatar
go to windows-font folder ,back up the fonts you want to remove,then delete it. if you want to reinstall ,simple paste that font in font folder
you never know what you can do until you try
digiFriend is offline
Old 29-04-2006, 02:16 PM   #6 (permalink)
The Researcher
Please Do Not Delete The "fonts" Folder Itself. If You Delete, You Will Not Be Able To Boot Into Your System.
Ramakrishnan is offline
Old 29-04-2006, 03:13 PM   #7 (permalink)
tuxfan's Avatar
There was a Word macro that lists all fonts installen in your system. Then you can select which ones you don't want and delete the unwanted ones. That word macro can be really helpful.
Here's the code
Sub ListFonts()
' ListFonts Macro
' Macro created 27/04/2005 by tuxfan
Dim f As Variant
    Documents.Add
    With ActiveDocument.PageSetup.TextColumns
        .SetCount (2)
        .LineBetween = True
    End With
    Selection.Font.Size = 14
    For Each f In FontNames
        Selection.Font.Name = f
        Selection.TypeText (f & vbLf)
    Next
End Sub
tuxfan is offline
Old 29-04-2006, 06:43 PM   #8 (permalink)
Distinguished Member
anandk's Avatar
click here, go to pg 38 to see the list of windows screenfonts required.
DONT delete thes.
http://www.totalidea.com/files/pdf/tweakxp4.pdf
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 30-04-2006, 06:55 PM   #9 (permalink)
hafees's Avatar
have a look at http://www.fontutilities.com
hafees is offline
- by Krow
