28-04-2006, 02:17 PM
Level 96 Headbanger
Suggest Freeware NTFS Partitioning tools
Greetings Everyone,
Can any one suggest any Free or Open Source tool to Partition my single volume NTFS drive. I have tried SwissKnife, but it does nt work on a single vol. and Partition Magic does nt install on my Partition.
It will also be very kind if you give steps on how to use it.
Thanks for all responses.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium (Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 ( New :twisted:), Roland MicroCube Amp.
28-04-2006, 02:28 PM
Re: Suggest Freeware NTFS Partitioning tools
try to use partition magic search the forum for more such tools
28-04-2006, 03:58 PM
Level 96 Headbanger
I tried Partition Magic, but it said-"Windows 2000 detected, Partition Magic does not support it".
The tools I searched on the Forum are partition resizers and unable to partition single volume drives.
If there is a new version of Partition Magic available, please tell its url.
Steam : DeathMetal
28-04-2006, 09:29 PM
Partition magic is not Freeware!!! There are a couple of good partition managers such as Ranish Partition Manager at http://www.ranish.com/part/ and there was another software recently (this month or last month) on Digit CD/DVD...
Arun
29-04-2006, 06:19 AM
You could always use Boot It! partition manager. Download it from http://www.terabyteunlimited.com .It is what I have been using and find it pretty good and easy to use. There is also a free partition manager provided in the April 2006 Digit CD. Look closely and you'll find it.
02-05-2006, 03:17 PM
Level 96 Headbanger
If you are talking about SwissKnife, it doesnt help. It says that it Detected OS system files on the drive hence cannot partition it for Security reasons.
I find it difficult to use PartitionLogic too. Has a somewhat DOS based interface.
@GUNNER
BootIt doesnt seem to be freeware, since it appears under the Purchase secion of the site.
Please try to suggest other tools that may be free.
Steam : DeathMetal
02-05-2006, 10:59 PM
Your Maker.
WINDOWS PARTITION MANAGER (in disk management)
Also, if you want to partition the whole HDD, inclluding the space with the OS installed, then reinstall WINDOWS and you'll get an option that asks abt what size the partitions should be during installation. (in WIN XP, should be there in others as well, but not sure)
“Talent is a flame, but genius is a fire.”
04-05-2006, 12:48 PM
Level 96 Headbanger
@MysticHalo
Tried my best on that too. I aint got no Partition, but a single 20 GB (18.6GB) volume. I defragmented but didnt find any unallocated space. Can you help me in steps as how to partition my drive. I plan to install Fedora Core.
Steam : DeathMetal
04-05-2006, 04:13 PM
use "seagate disk wizard ":
it will make bootable disk which will help in harddisk format and has harddisk utilities. other company harddisk have similiar software on their website.
or "Ultimate boot CD"
BOOTABLE cd with trouble shooter
you never know what you can do until you try
07-05-2006, 05:46 PM
Security Exp
XP embeded feature can b used to serve ur need go to administrative tools in control pannel in disk management chose drive u want to partion as NTFS and here u go. ONE prob with this is u can use this option thenu have to delete partion then create it as NTFS impies data will b lost. use Segate s\w or partion magic as a better option over this. but later are commercial and had a price tag to pay
09-05-2006, 01:51 PM
Level 96 Headbanger
Settled with BootItNG.
Only its installation is trial. If run off a floppy, it easily resizes partitions and creates them too.
Anyway, thanks everyone for your suggestions.
Steam : DeathMetal
Search this Thread |
