Old 10-11-2004, 01:19 AM   #1 (permalink)
sunnydiv
Posts: n/a
Default leme c if i got this right !!!!
if u buy xp (orignal ) then insatll on a machine, then upgrade ur pc
do u have to by xp again !!!!
Old 10-11-2004, 01:42 AM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Nah .. You'll have to reactivate it again ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 10-11-2004, 01:46 AM   #3 (permalink)
sunnydiv
Posts: n/a
but when u activate then it records ur machine specs
so when specs change, it detects thgat machine has changed, then what u do
cos it cant be that it doesnt
Old 10-11-2004, 01:47 AM   #4 (permalink)
I dont think so, there sure is some better way to do it.
**** happens
pradeep_chauhan is offline
Old 10-11-2004, 11:17 AM   #5 (permalink)
club_pranay's Avatar
dude, if u open the License agreement u'll see that it's almost impossible to stick to law. even if u copy the installation cd thinking that u better use the copy so that the original is kept at a safe place, u've just broken the law!!!
there's no point spending too much on "old" Xp when longhorns are on the way
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 10-11-2004, 11:24 AM   #6 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
u need to activate again...
actually WPA periodically checks ur hardware changes and match it with what WPA collected before.. if u change throughout hardware like CPU/RAM/GPU... then u may need to reactivate again... on small hardware changes u may not need....
it depends on what stuff about SLP/BIOS/HW they collected thru WPA when u activated first time...
read this WPA guide for more info http://www.geocities.com/shekharpalash/docs/WPA.pdf
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 10-11-2004, 02:10 PM   #7 (permalink)
Dude.. i have Original XP.. thou i havent upgarded system, i have chnaged Harddisks / RAM, re-instyalled OS.. NOT had problems so far..
But not sure if u're totally upgarding.. but ium sure u'll get enough support from MS.. and i guess what shekar says is rite..
SmoothCriminal is offline
- by Krow
