Old 17-07-2004, 08:10 PM   #1 (permalink)
Default Please Help Regarding Redhat 9 Installation
Please tell me how to install redhat9 on my windows xp running laptop.
[Edit : Batty] Please post relevant subject for your threads
undertakerthedead is offline
Old 18-07-2004, 12:51 AM   #2 (permalink)
Default Re: Urgent Pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeaaaaaaaase help
First insure if you have the proper drivers. Linux drivers can be quite a hassle if u can't compile them yourself. Try posting ur system specs on linux forums and mebbe someone will take the trouble to compile the drivers for you. Someone usually does!
U think U know better...???
Naga is offline
Old 18-07-2004, 01:40 AM   #3 (permalink)
#/bin/sh's Avatar
Teaching someone a installing red hat linux is a very big task, and not something you would do in a forum , chat room or over email. There is a reason why hardware and other courses cost a lot of %currency%. So you'll probably not find anyone willing to to teach you here. Try getting a good book instead
\"99 little bugs in the code, 99 bugs in the code, fix one bug, compile it again, 148 little bugs in the code. 148 little bugs in the code....\"
#/bin/sh is offline
Old 18-07-2004, 01:41 AM   #4 (permalink)
#/bin/sh's Avatar
check the Manuals here in pdf looks like book
http://www.redhat.com/docs/manuals/linux/
#/bin/sh is offline
Old 18-07-2004, 02:35 PM   #5 (permalink)
first give ur config and also what file system u r using on ur hard drive and the partition details. then i guess we can take it frm there. ppl will help. the reason im asking u 4 the hdd details is that if u have da ntfs system, then linux will not install-u need a fat32 partition. da installation is not really complex.
Nemesis is offline
Old 18-07-2004, 11:13 PM   #6 (permalink)
FooBar Guy
GNUrag's Avatar
Is this your first time? I highly recommend getting hold of the latest Knoppix 3.4 CD. Its really easy to install and gets cloned on ur hard disk in 10 - 15 mins.
It comes bundled with QTparted which is a Partition Magic clone. You can do any damn thing with ur hard disk that you want. Contact me offline for more help.
anurag
http://web.gnuer.org
GNUrag is offline
Old 19-07-2004, 01:05 AM   #7 (permalink)
gnurag is right if it is ur first time in linux u may try knoppix or better still suse live eval.
If you really want to install redhat 9 in ur laptop refer to the rehadat mannuals provided in their website (if u ahve patience to read all that) or spend a few bucks to buy books like redhat bible(it is the best for general learning).
But it would be better if you manage to refer to the august 2003 issue of digit they provided excellent brief description of installing redhat(page 92).
I don't think that drivers would be a problem ,redhat 9 has good collection of drivers.but the internal laptop modem may be not be recognised.(if this happens try to get a linux drive from manufacture's website)
It_is_Andrew is offline
Old 19-07-2004, 08:17 PM   #8 (permalink)
yup for trial its allright but then if u really wanna try out linux u should go for redhat 9.0
has the most extenxive hardware support as much as i know
so there u will b havin minimal if not any probs man
Death is the RULE
while,
survival is an EXCEPTION
silverTwins is offline
Old 21-07-2004, 12:38 AM   #9 (permalink)
#/bin/sh's Avatar
it seems we losse the undertakerthedead.
#/bin/sh is offline
Old 21-07-2004, 11:20 PM   #10 (permalink)
Post your Lappy's configuration n vendor.
If ur lappys still under warranty ,then dont mess with it.
Contact your vendor for help.
If not then :
Where did u get ur Redhat9 from ,do u have all the cds.
Do u have any previous experience of installing os.
Are u comfortable if u have to Edit your partition table.
Does ur Lappy have a floppy drive.
Reply n ill try to help u out.
amitsaudy is offline
Old 25-07-2004, 01:44 PM   #11 (permalink)
So many e's eh?
The coolest place to be on the net Zone Area
sonuchandrakar is offline
Old 25-07-2004, 05:02 PM   #12 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Ok .. Check the HowTos described in the thread ...
http://www.thinkdigit.com/forum/view...960&highlight=
And Next time think of some more elaborative subject for your thread ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 04-08-2004, 07:27 PM   #13 (permalink)
here is the config
acer
p4 2.66ghz
256mb ram
16 mb onboard graphics
windows xp
ntfs
40gb
2 paritions
Old 05-08-2004, 02:13 PM   #14 (permalink)
Default I think it requires only a normal installation procedure
I think it would not be very complicated task to configure the listed configuration.
Major problem arises in case of a modem or network card.
So I think just installation from RedHat CD would be enough, if you have prior experience !
Otherwise make a google search and u'll find the documentation on the proper installation of Linux..
naveen_kanthed is offline
Old 05-08-2004, 02:16 PM   #15 (permalink)
ntfs? linux wont install on ntfs
Nemesis is offline
Old 05-08-2004, 09:01 PM   #16 (permalink)
Will have to resize your ntfs partitions.
Check if PartitionMagic is available for WinXP.
Old 06-08-2004, 04:43 AM   #17 (permalink)
Posts: n/a
Wizzz..
Best you can try thr 'XandraOS' with 6 r 7 clicks it automatically installs linux.No other partiton mounting risks r required.This is available with july 04 LFY, It is a 1gle cd installs on the fly, also supports all the h/w configs.But b4 u can free up one partition. the
2.6 ver kernel supports NTFS also.
Old 07-08-2004, 09:24 PM   #18 (permalink)
Does it include the Gnome & Kde desktops.
Old 14-08-2004, 11:01 PM   #19 (permalink)
read digit aug 03 or chip feb 04 mag.if u have installed win earlier u will be able to do it.I did it without reading any mag or manual it's quite easy.the only tricky part is where you have to specify your hd partition so get your neighbourhood linux geek to do it.
godfather is offline
Old 18-08-2004, 06:07 PM   #20 (permalink)
Follow the steps:
1. Ensure that you don't have any software INSTALLED on D:
2. Transfer all your data from D: to C: in a folder (this is temporary)
3. Right click on "My Computer" on the desktop.
4. Click "Manage".
5. Goto Storage->Disk Management in the left pane
6. Right Click your D: in right pane.
7. Delete that drive (Check for steps 1 & 2 before you do this!).
8. Right click on the unallocated space (earlier that was your D: )
9. Create partition leaving around 4 GB as unallocated space. (Suppose your D: was of 20 GB, then create new partition of 16 GB)
10. Format the new D: keeping it NTFS or FAT32 (16 GB as said above)
11. Transfer your all data in D: back
12. Now your 4 GB is unallocated and free for linux installation.
13. Boot the system with the First Linux boot CD.
14. In most cases it automatically detects the unallocated space and you can use "Autoallocate" for this 4 GB space.
15. Follow the onscreen instructions for installation of linux.
Even if you can not install the linux properly here, your windows xp system will work without any problem except lack of that 4 GB space.
jnpandya is offline
Old 18-08-2004, 06:10 PM   #21 (permalink)
YOU WILL BE ASKED ABOUT USING FULL HARD DISK TO INSTALL LINUX.
BEWARE! YOU HAVE TO USE ONLY UNALLOCATED SPACE.
jnpandya is offline
Old 18-08-2004, 09:32 PM   #22 (permalink)
Next time, Pleeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeaaaaaaaase use a coherent topic title! Sheesh!
wORm is offline
Old 19-08-2004, 12:09 AM   #23 (permalink)
yes u need 2 fat 32 partitions one large for the os, the other 3 times size of available ram for the swap memory
Attack life, it\'s going to kill you anyway.
walking-techie is offline
Old 30-08-2004, 08:12 PM   #24 (permalink)
i installed it a long time ago so i don't remember the correct sr. no.
1 insert cd 1 (mk sure your cd rom drives ranks 1st in boot order )
2 choose graphical user interface
3 insert all needed info.
Imp- Choose Grub as boot loader. Choose auto disk partition. Or manually format the empty space as ext3.Please make a / partition and a swap partition to keep running -- latter not recommended.
4 remember ur root password
5 set date time etc.
6 set firewall details.
7 choose ur default setting i.e-PC, server, custom etc.( if u r a novice don't play with packets)
8 itll ask for cd 2 and 3
9 Give the necessary info for post install setup
10 restart
11 Setup wizard will take neccassary action.
12 Enjoy-- Main Hoon Na
tushar_novice is offline
Old 17-09-2004, 01:42 AM   #25 (permalink)
parthbarot's Avatar
u have to first some unspecified spaxce
means format one drive & delete partition.
then insert Bootable of linux
it will auto matic select that space (shioul be 4 to 6 GB).
it s easy yaar
homepage====www.freeinfonet.tk
www.techlads.com
Paarth.
parthbarot is offline
Old 19-09-2004, 06:28 PM   #26 (permalink)
I HAVE INSTALLED RED HAT LINUX 7 TIMES.
FIRST INSERT THE 1st CD OF RED HAT 9.0 INTHE DRIVE.
BOOT FROM IT
PRESS ENTER TO SELECT THE GRAPHICAL INTERFACE.
CLICK NEXT(LANGUAGE SELECTION)
CLICK ON HOME PERSONAL PRESS NEXT.DONT SELECT SERVER OR WORKSTATION INSTALLATION.
CLICK MANUAL PARTITION WITH DISK DRUID.
DELETE A WINDOWS PARTITION OF 6 GB PLACE.(FINE SPACE WITH FREQUENT WORKS)
MAKE A NEW PARTITION EXT3 OF 5.5 GB AND MAKE ANOTHER 500 MB AS SWAP PARTITION.
CLICK NEXT
SELECT THE BOOT LOADER.IF U R A NOVICE LEAVE THE SCREEN DEFAULT AND INTACT.
PRESS NEXTAGAIN PRESS NEXT DONT PLAY WITH PACKAGES DEFAULTS ARE ENOUGH.
INST WILL START.
NOW VERY EASY INSERT THE REQ CD'S WHEN REQ.
U R GONE! JUST ENJOY!!
BUT BE CAREFUL NOT TO FORGET PASSWORD AND DO NOT PLAY WITH RED HAT 9.0 ELSE IT WILL MAKE U RED HOT.
Writankar panja is offline
Old 19-09-2004, 08:45 PM   #27 (permalink)
BOOT FROM IT
CLICK NEXT
INST WILL START.
hmmmmm i think installing the suse from digit dvd will be also quite easy i want to install that . ne suggestions for that ?
suhas_sm is offline
Old 29-09-2004, 12:49 PM   #28 (permalink)
U can install SUSE directly from its image.
No need for burning it onto a cd.
Check this link http://www.thinkdigit.com/howto.html
- by Krow
