Old 27-04-2006, 09:25 AM   #1 (permalink)
Default html link help
hi all,
i've downloaded some files from the links in html file....now that I've downloaded those file, i want to edit those link to point the location in the hard drive!! i know its easy....i'll open the html in notepad and change the url, but I want to open the file in the default directory, so that even if i change the location of the files, the link remain intact???
thax
jack// ani is offline
Old 27-04-2006, 10:00 AM   #2 (permalink)
sknowonweb's Avatar
Whats do u mean by default directory , Is it the directory u place ur HTML files .
Does providing absolute path names solve that .
Please make that more clearer .
தமிழ் வாழ்க
____________
EVIL : G00D :: YIN : YANG
________
sknowonweb is offline
Old 27-04-2006, 11:43 AM   #3 (permalink)
hi sknowonweb,
ya...you got it right!! By default directory i mean to say the directory in which I place HTML file and other downloaded files!! sorry for that confusion....
what is absolute path name??
thax
Old 27-04-2006, 11:57 AM   #4 (permalink)
sknowonweb's Avatar
That is
<<<, a href = "koli.jpg"> means a relative path
<a href="D:\asp\powe.htm"> means a absolute path
by this a source html file can be anywhere but only works on ur comp.
relative path works on any computer as all files are almost in same directory
தமிழ் வாழ்க
____________
________
- by Krow
