Old 26-04-2006, 11:14 AM   #1 (permalink)
Default webcam recording
hii all
well i need a software using which i can record whatever i see during a webcam chat. can ne one plz tell me a software which can do this, or by ne other means through which the recording is possible. i use yahoo msngr, n need d software for it.
thnx
kingshere is offline
Old 26-04-2006, 11:23 AM   #2 (permalink)
l33t n00b!
Nimda's Avatar
You can try out these apps:
1. Memento LE
2. CamGrab 2
3. Bulent Screen Recorder
Nimda is offline
Old 26-04-2006, 09:00 PM   #3 (permalink)
hey nimda,
thnx for ur links, bt i would like a freeware. wht u gave were trial versions,
Old 26-04-2006, 09:59 PM   #4 (permalink)
l33t n00b!
Nimda's Avatar
Version 1.5a of the last link (Bulent Screen Recorder) is freeware. Check out this file. If the link's not working, try searching for "InstallBSR_v15a.exe"
Nimda is offline
- by Krow
