Old 09-11-2004, 03:40 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Screensavers for mobile ???
I use OPM 2 ... & an ir device ... 4 my mobile connection ...
wanna install screensaver in 2 my phone 6610 ... as i have many of them downloaded from net ...
how can i do it ??? no option in op2 ...
Edited Batty for subject relevance
ax3 is offline
Old 10-11-2004, 03:56 PM   #2 (permalink)
ax3
ax3's Avatar
hey ... koi mobile freak nahi hai kya ???
anybody ... who has tried installing ssavers on mobiles ...
help
... W H O T ...
ax3 is offline
Old 04-01-2005, 03:28 PM   #3 (permalink)
harish_21_10's Avatar
Main hoon na...
if 6610 support the coloured screen savers then u can install it and change the it from the screen saver settings.If not then u may need to install to any extra application for changing the screen savers.
I used psilco screen saver changer in my 7610 and worked just fine.
harish_21_10 is offline
- by Krow
