I am using Avast Home Edition and its On-access scanner. Is it suited for P.C? Do I need another products like AVG, MacAfee, Norton etc., and which one is better?
I think your Avast Home Edition is good enough if you update it regularly.
If you doubt the efficacy of your antivirus please specify the nature of your doubt.
Never use more than one AntiVirus software on your system. It causes nothing but harm to both your system resources as well as your security. Avast is a good free AntiVirus but if compared with AVG 7 (which is also free), it lacks in detection capabilities of very small margin. To check out a detailed comparison of the detection capabilities of various AntiVirus software, I would recommend the following test result http://www.virus.gr/enghttp://www.vi...p?id=72&mnu=72
its better to get avast! proffessional edition if u r using ur PC in business.
but for home use, avast free edition is the BEST.
I don't know abt any AV softwares coz i never used that!
I don't know abt any AV softwares coz i never used! that
If you don't know about and never used an AV, what do you mean by giving such suggestions?
