Old 09-11-2004, 03:01 PM   #1 (permalink)
Default coputer restarting
My computer restarts automaticaly. i have checked my power outlet and repluged all power cables. pls help me
deeps is offline
Old 09-11-2004, 05:50 PM   #2 (permalink)
vysakh's Avatar
welcome to digit
the problem is not very clear
specify ur config, when does this happen & aby new things u installed
Incompatible message format
vysakh is offline
Old 10-11-2004, 12:20 PM   #3 (permalink)
Default motherboard
Get ur motherboard checked.
as4878 is offline
Old 10-11-2004, 01:15 PM   #4 (permalink)
yep u need to specify full specification , including OS and just when its hapenning.
[url]http://gameunion.forumer.com[/url]
[url]http://sumanpaul.modblog.com[/url]
sumanpaul is offline
Old 10-11-2004, 10:26 PM   #5 (permalink)
Version 2.0
Deep's Avatar
press windows button + pase/break (or prop or my computers)
- adavnced tab - setp and recovery button - uncheck Automaticlly Retstart in System failure option
so from now it shall show blue screen instead of reboot..
so if it happens again then note down the code and paste it here...
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 12-11-2004, 12:19 AM   #6 (permalink)
What antivirus are you using? If your system configs are allright, then it might be a virus.
Hard work never killed anybody..........But why take the RISK
indrajit is offline
Old 12-11-2004, 12:34 AM   #7 (permalink)
mmmmmmmmm
Seems 2 b an OS problem.
Using XP??? Put it in - Best known config. Can do dat by Alt+f4 @ startup.
I think u need to just give more info. i mean when does it restart? The above wrks only 4 startup probs. pls let us know here ur OS
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
Aseem Nasnodkar is offline
- by Krow
