I have a lite On dvd burner. Its model No: SOHW-1633s
Some times when i burn i get a session fixation error and nero says it cannot do disc at once.
I use nero 6.3
Please see the Log file i have pasted.
LOG FILE
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 9:20:56 AM
ahead WinASPI: File 'D:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 11/11/2003 2:49:52 PM
Nero version: 6.3.0.0
Recorder: <LITE-ON DVDRW SOHW-1633S>Version: BS0K - HA 3 TA 0 - 6.3.0.0
Adapter driver: <atapi> HA 3
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <LITE-ON DVDRW SOHW-1633S>Version: BS0K - HA 3 TA 0 - 6.3.0.0
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG SV1204H atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVDRW SOHW-1633S atapi Port 3 ID 0 DMA: On
=== CDRom-Device-Map ===
LITE-ON DVDRW SOHW-1633S H: CDRom0
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 72351744 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 494MB (506604kB)
Free physical memory: 270MB (277268kB)
Memory in use : 45 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
8.11.2004
ISO compilation
8:43:23 PM #1 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : TRUE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
8:43:23 PM #2 Text 0 File Reader.cpp, Line 118
Reader running
8:43:23 PM #3 Text 0 File Writer.cpp, Line 124
Writer LITE-ON DVDRW SOHW-1633S running
8:43:23 PM #4 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
8:43:23 PM #5 Text 0 File Burncd.cpp, Line 3094
Turn on Disc-at-once, using DVD media
8:43:23 PM #6 Text 0 File DlgWaitCD.cpp, Line 239
Last possible write address on media: 2297887 (510:38.37)
Last address to be written: 2293359 (509:38.09)
8:43:23 PM #7 Text 0 File DlgWaitCD.cpp, Line 244
Write in overburning mode: FALSE
8:43:23 PM #8 Text 0 File DlgWaitCD.cpp, Line 2068
Recorder: LITE-ON DVDRW SOHW-1633S, Media type: DVD-R
Disc Manufacturer: PRINCO -
Disc Application Code: 64, Disc Physical Code: 193
8:43:23 PM #9 Text 0 File DlgWaitCD.cpp, Line 405
>>> Protocol of DlgWaitCD activities: <<<
8:43:23 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2293360 (2293360) = #2293360/509:38.10
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2293360 blocks [LITE-ON DVDRW SOHW-1633S]
8:43:24 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [LITE-ON DVDRW SOHW-1633S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4696801280, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2293360 | lead-out | 1 | 0x00 | 0x41
8:43:24 PM #12 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
8:43:24 PM #13 Text 0 File Burncd.cpp, Line 4061
Cache writing successful.
8:43:24 PM #14 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
8:43:24 PM #15 Phase 32 File dlgbrnst.cpp, Line 1800
Simulation started at 4x (5,520 KB/s)
8:43:24 PM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
8:43:24 PM #17 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 14:12,890 (852890ms) -> OK
8:43:24 PM #18 Text 0 File DVDR.cpp, Line 1424
Recording mode: Sequential Recording Mode
8:43:24 PM #19 Text 0 File Mmc.cpp, Line 19397
Set BUFE: supported -> ON , SMART-BURN : ON
8:43:24 PM #20 Text 0 File DVDR.cpp, Line 1539
Start write address at LBA 0
DVD high compatibility mode: Yes
8:43:24 PM #21 Text 0 File Cdrdrv.cpp, Line 7912
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
8:43:26 PM #22 Text 0 File Cdrdrv.cpp, Line 1276
20:43:26.656 - LITE-ON DVDRW SOHW-1633S\H3 T0 : Queue again later
9:00:12 PM #23 Text 0 File WriterStatus.cpp, Line 115
<LITE-ON DVDRW SOHW-1633S> start writing Lead-Out at LBA 2293360 (22FE70h), lenght 0 blocks
9:00:12 PM #24 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
9:00:12 PM #25 Text 0 File DVDR.cpp, Line 1743
EndDAO: Last written address was 2293359
9:00:36 PM #26 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
9:00:36 PM #27 Text 0 File dlgbrnst.cpp, Line 1658
9:00:41 PM #28 Phase 33 File dlgbrnst.cpp, Line 1800
Simulation completed successfully at 4x (5,520 KB/s)
9:00:43 PM #29 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 4x (5,520 KB/s)
9:00:43 PM #30 Text 0 File ThreadedTransferInterface.cpp, Line 2264
9:00:43 PM #31 Text 0 File dlgbrnst.cpp, Line 1658
9:00:43 PM #32 Text 0 File DVDR.cpp, Line 1424
9:00:43 PM #33 Text 0 File Mmc.cpp, Line 19397
9:00:43 PM #34 Text 0 File DVDR.cpp, Line 1539
9:00:43 PM #35 Text 0 File Cdrdrv.cpp, Line 7912
Media Specific:
9:01:22 PM #36 Text 0 File Cdrdrv.cpp, Line 1276
21:01:22.156 - LITE-ON DVDRW SOHW-1633S\H3 T0 : Queue again later
9:15:39 PM #37 Text 0 File WriterStatus.cpp, Line 115
9:15:39 PM #38 Text 0 File ThreadedTransfer.cpp, Line 229
9:15:39 PM #39 Text 0 File DVDR.cpp, Line 1743
9:17:13 PM #40 SCSI -1176 File Cdrdrv.cpp, Line 1170
SCSI Exec, HA 3, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x72
Sense Qual: 0x02
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x02
9:17:13 PM #41 Text 0 File dlgbrnst.cpp, Line 1658
9:17:13 PM #42 CDR -1176 File ThreadedTransferInterface.cpp, Line 1659
Session fixation error
9:17:13 PM #43 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1659
Could not perform end of Disc-at-once
9:17:13 PM #44 Text 0 File DVDR.cpp, Line 1743
EndDAO: Last written address was -1
9:17:13 PM #45 Text 0 File dlgbrnst.cpp, Line 1658
9:17:13 PM #46 Text 0 File dlgbrnst.cpp, Line 1658
9:17:13 PM #47 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 4x (5,520 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 7/17/2002 8:53:02 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.57a, size=17168 bytes, created 7/30/2003 2:32:00 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1164 (xpsp2.021217-1051), size=87040 bytes, created 1/31/2003 3:43:30 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
[Edited Batty] For making relevant the subject
