Old 16-04-2006, 10:52 AM   #1 (permalink)
Default Installation doesn't start.
I've downloaded trial version of Pinnacle Studio_9_3 (214 MB) in my office compiter. Upon double-clicking the prog its installation starts in that computer. However, when I copied the same prog on a CD-RW media and tried to install it in my Home Cpmputer the installation process does not start there at all . Even no error message is also flashed. I've copied a no. of times but the same thing happened (that is to say NOTHING HAPPENED ). I even downloaded the prog for second time but ended with the same result. My Comp. is Win XP (SP2) and for copying I've used the built-in Roxio prog and also Nero Burner.
Plaese give any clue.
abhijitroy is offline
Old 16-04-2006, 11:03 AM   #2 (permalink)
l33t n00b!
Nimda's Avatar
Seems there is some problem with the CD-RW media. You could burn the file onto a multi-session CD-R and see if the installation file opens on your home PC. Otherwise, you could take the CD drive in your office PC and connect it to your home PC and see if the setup file in the CD-RW opens (some drives are better at reading CD's than others). Also try writing at different speeds.
Nimda is offline
- by Krow
