Old 16-04-2006, 09:27 AM   #1 (permalink)
Default How to block website using regedit
Hi all,
I want ti ask all u master mind is that is there any solution on website blocking using regedit without using any soft.
I want to know how to block certian website using regedit.
Thanx
Dinesh
dineshgaur1 is offline
Old 16-04-2006, 02:21 PM   #2 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
I assume you use Internet Explorer and want to block some website from being accessed on your computer. For this you can use Content Advisor.
In IE, Do this :
Tools > Internet Options
Click on Content tab.
In the Content Advisor frame, click on Enable.
Now in the Approved sites tab, you can manage the websites that you want to block or approve to the users.
And on the General tab, set a Supervisor Password so that only you can change the settings.
Here is a screenshot :
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 16-04-2006, 08:49 PM   #3 (permalink)
But i want to do it by regedit these settings are cooman to all user i want
block it by using regedit.
Thankx
Old 16-04-2006, 11:48 PM   #4 (permalink)
Those settings are common to all users.
Old 16-04-2006, 11:58 PM   #5 (permalink)
shoegoe's Avatar
There a way to block websites through registry? Wow.. never heard of that..
If you block a web in registry(IF POSSIBLE), doent it mean that your IE rejects that domain(IF). Even so, you can access the website through other browsers that works without ie engine.. like ff..i dont think imposing a registry value can control all the browsers. dont they have different agents?.....
shoegoe is offline
Old 17-04-2006, 12:57 AM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Some viruses do that I guess, to block access to anti-viruse sites... I dont know how...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 17-04-2006, 07:46 AM   #7 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ They use "hosts" file..
kalpik is offline
Old 17-04-2006, 07:52 AM   #8 (permalink)
Commander in Chief
Oh ok, I thought it was registry
Harsh J
www.harshj.com
- by Krow
